Question about EdgeStar BWC120SS (36 cu ft) Wine Cooler Beverage Cooler
Where is the fuse in an edgestar beverage cooler
3 Suggested Answers
  • 1833 Answers
SOURCE: I HAVE A EDGESTAR BWC120SS
It sounds like the compressor is bad; you may need toreplace it. Also check for the condenser coil, if it was completely blocked. Open the cover and check for the board also. Good Luck.
Posted on Jul 15, 2011
rickead1
  • 1998 Answers
yes its called the start relay/overload
Thanks Rick
p.s finding who has the part may be a bugger though might want to pull out the manual and find who the manufacturer is and contact them for the part Thanks again Rick
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Kegerator gets cold but will not not stay cold. its like unit shuts off after it reaches cold
You may need to replace the thermostat. Sound like it works until the low temp setting is reached and then can't maintain that temperature. Given that it will turn the machine on when the refrigerated compartment is warm this implies that the thermostat works until it breaks the connection when the low temperature target is reached.
Jan 07, 2014 | EdgeStar KC2000 Beverage Cooler Commercial
Edgestar cwr300sz
This cooler's operating range is 40-65 F. If it is still in warranty contact the manufacturer. You could have a faulty thermostat. If so have it replaced.
Dec 30, 2013 | EdgeStar BWC120SS (36 cu ft) Wine Cooler...
Edge star not cooling and clicking sound
the clicking sound may be the condenser fan. if the compressor is running, check to see if there is dust or ice blocking the air flow on the condensor or if the fan is moving slow. this will prevent cooling. remove any obstructions and replace the fan if necessary
Nov 24, 2013 | EdgeStar BWC90SSLT - 84 Can Supreme Cold...
Wine cooler not cool
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
Edgestar wine cooler eh error code
You can download the owner's manual at: http://www.edgestar.com/TWR215ESS-EdgeStar-21-Bottle-Dual-Zone-Wine-Cooler/TWR215ESS,default,pd.html?cgid=Wine_and_Beverage-Wine_Refrigerators
Apr 10, 2013 | EdgeStar TWR181ES
Light won't come on beverage cooler?
The unit should still be in warranty. Contact Edgestar for help.
Feb 22, 2013 | EdgeStar Refrigerators
Wine cooler stopped working
If it is still in warranty contact EdgeStar.
Jan 16, 2013 | EdgeStar TWR282S Wine Cooler
Is there a way to change the factory settings to make it colder?
KC2000, BRL2000BL, BRL2000SS: How to set temperature range to a cooler setting.
Unplug the unit from power
1. Unfasten screws indicated below.
2. Carefully pry the knob off.
3. Slide the dial out of the box.
4. Unfasten the screws with a Phillips screw driver.
5. The thermostat adjustment screw can be modified by, FIRST turning the screw clockwise until it is "finger snug" - DO NOT OVER-TIGHTEN.
THEN turn it counterclockwise 2 total turns.
6. Reassemble. Test for 24 hours. If the temperature is too cold, repeat steps 1-5 and in step 5 turn the screw counterclockwise three total turns instead of two.
Jan 08, 2011 | EdgeStar KC2000 Beverage Cooler Commercial
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
EdgeStar BWC120SS (36 cu ft) Wine Cooler Beverage Cooler Logo
95 people viewed this question
Top EdgeStar Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an EdgeStar Refrigerator Expert? Answer questions, earn points and help others
