Question about Silverstone SST-ST60F (SSTST60F) 600-Watt Power Supply
AFTER POWER OUTAGE IT IS DEAD - Silverstone SST-ST60F (SSTST60F) 600-Watt Power Supply
    Genius:
  • 1,212 Answers
Voltage spike likely blew across the dielectric of several electrolytic capacitors. The internal fuse may or may not have survived. If it did not- replace it once and see if it is as simple as that, although you are likely looking something more.
If you want to try to salvage it, recap all electrolytics and tantalums. with new high ripple current types for the electrolytics.
Posted on Feb 07, 2012
Reset after power outage
Most programmable thermostats have batteries to keep the program from being lost in a power outage. If you thermostat has dead batteries or no batteries a power outage will cause the thermostat to revert to a default setting and it will have to be reprogrammed. Hope this helps.
Dec 22, 2013 | Honeywell Heating & Cooling
Motorola dcx 700 no power since a slight power
It's possible that the box is dead and need's to be replaced. One thing you can try is rebooting the box by unplugging the power cord and then plugging it back in. You can also try plugging it into a different outlet. Are you sure it's the box that's dead and not the tv?
Oct 14, 2013 | Televison & Video
After power outage compaq presario SR1123WM desktop wont turn on
cHECK THE ps IF GOOD CHECK THE mobo COMMN BECOME DEAD AFTER POWER SURGE.
Nov 06, 2011 | Computers & Internet
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Hello, my HP Pavilion desktop PC m9177c went dead after a power outage. Right before the outage, it was on and connected to a surge protector. After the outage, it is completely dead as if there is no...
You may have to change its power supply however, try this first
1. change your UPS coz the old one may have been damaged.
if that still didn't work, change your power supply
Nov 28, 2010 | HP Pavilion a710n (PJ508AA) PC Desktop
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
Mar 19, 2008 | Samsung Prostar 816 Phone
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
HELP! power outage problem
Your burglar alarm panel, shorts the phone line when it sounds off, while it is auto dialing out. So that is why no phone.
My strong recommendations is to use a UPS on all of the items that are on the phone line. Problem should be solved.
You don need big ones either. Small ones will do just fine. I have them too.
www.storminproteciton.com
Jan 05, 2008 | Panasonic (KX-TG1032S) Phone
Went dead after power outage all other components ok
Hi there!
Power surges are common after the electricity is re-established. The reason some and not all are damaged is because the closest point or the weakest supply is normally taken out first. A job for a repair technician if your are not familiar with the inside of a TV. May just be a fuse if you are lucky. If the led comes on in standby only it is normally more serious. Good Luck,JUS004
Dec 17, 2007 | Sanyo DS35510 35" TV
Silverstone SST-ST60F (SSTST60F) 600-Watt Power Supply Logo
104 people viewed this question
Top Silverstone Computers & Internet Experts
David Payne
David Payne
Are you a Silverstone Computer and Internet Expert? Answer questions, earn points and help others
