Question about Philips Televison & Video
I have a Philips 60-Inch DLP Projection HDTV model# 60PL9200D/37 won't power up or down when you plug it in you hear the motor come on but only thing that happens is the power button blinks blue. Real fast then slow
    Top Expert:
  • Philips Master
  • 74,136 Answers
Hello
Its main board [motherboard] will have some short circuited component/s. To locate the exact faulty component, you have to check the main board. Normally, DLP control chip are found faulty to this type of sets. You must have through knoledge and expereince to work with this type of Tv circuits, and must have its schematic diagram [service book], all tools to proceed. OK.
Posted on Feb 08, 2012
3 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Posted on Nov 18, 2008
SOURCE: Philips 60pl9200D/37. Two Red lights on power button.
i had the same problem with mine the fan ur talkin about is discontinued so u need to get a fan with a special function for rotation detection i got mine from coolpc.com
Posted on Aug 22, 2010
I have a 60pl9200d/37 philips dlp tv. I replaced the bulb with a brand new one and I am still receiving the bulb issue indicated by the blue lights. Any ideas?
I don't know the model but it would seem a reset would do the trick. See if there is a button on the cpu board and that should do the trick if not try unplugging a re plugging unit . Logic needs reset by a switch or by removing power
Feb 19, 2015 | Philips Televison & Video
60PL9200D/37 TV picture problem
Sounds like one or both of your IC chips burnt out. You will need to replace them. A good place to purchase high quality IC chips is convergencechips.com.Be careful there are a lot of fakes out there that don't last and cost you more money in the long run.
Mar 07, 2012 | Philips 60PP9202 60" Rear Projection...
I have a philips 60pl9200d/37 the picture is fairly dark even though I've turned the brightness all the way up
The lamp can cause a dark picture if it is defective. There is an access door to the lamp. Take the lamp out and inspect it. Especially at the bottom of the center stem where you may see a bubbling of the glass. If so it is bad for sure. Other problem could be in the main board. For good price on lamp with housing go to pureglare.com and enter the model number.
Oct 24, 2011 | Philips 60PP9202 60" Rear Projection...
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I have a philips tv model number is 60PL9200D/37. when i turn on my tv the blue power light flashes and the lights and fans cut on but not the actual screen. after a few seconds of blinking the lights and...
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Feb 03, 2011 | Philips 60PL9200D Projection Televisions
How to replace the bulb in PHilips tv model 60PL9200D/37 ?
my tv flashes 6 times slow,pause,5 times fast but it dont power on
Sep 23, 2010 | Philips 60PL9200D Projection Televisions
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
