Question about SanDisk Sansa e250 MP3 Player
Can't turn on the Player!!!
I can't turn on the player!!! The PC can't even find the device!!! Absolutly nothing happened...Why is this?!?! Anyone help please?
  • 4 more comments
  • simonwebb13 Jan 17, 2009
    same as above
  • trixevix Jan 18, 2009
    I just got this mp3 player yesterday. Was working fine, but now it wont even turn on. When I plug it in to the computer, nothing happens. Don't know what to do to fix this. This is the second one I have had, I just replaced the first one yesterday for the same problem. Don't think this is a fluke.
  • selvarajmr2 Feb 20, 2009
    "Can't turn on the Player!!!" Even the computer didn't able to find out the drive...!
  • kemo1990 Feb 21, 2009
    my sandisk e250 mp3 player 2 problem 1- when i power it.. on comes ful wite screen . 2-my computer not reding device i need help to solv problem pls tanks
  • placerosa Feb 21, 2009
    cant turn on the player
  • alfietheonar Feb 22, 2009
    i have the same problem with my sanza
What i did when mine wouldnt turn on is unscrew the back and take the battery out wait a few seconds put it back on and it works fine
Posted on Aug 08, 2006
Polaroid MPU-43315B Personal Media Player stuck on 'initialize' -
i'm having the same problem. I'ts stuck on "Welcome" and nothing happens when i connect it to a computer
Feb 01, 2009 | Archos 104 MP3 Player
Sansa SanDisk mp3 out of power
Try these:
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 25, 2009 | SanDisk Sansa m240 MP3 Player
Doesnt even come on
Make sure the hold/lock switch is not engaged.
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Nov 17, 2008 | Philips GoGear SA3125/37 MP3 Player
It Bricked itself
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Aug 13, 2008 | Philips GoGear HDD6330 MP3 Player
DMP400N
Since I was unable to turn my Mp3 player off, it eventually ran out of battery!
I then connected it to my pc, and now it seems to work like a charm!
Jul 31, 2008 | Audio Players & Recorders
Coby MP-C827
It's probably just the mp3 player's malfunctioning on you...something must have happened during shipping and handling to the store you got it from.
May 27, 2008 | Coby MP-C883 MP3 Player
Pearl mp3 player
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 19, 2008 | Philips GOGEAR SA6045 MP3 Player
Player does not play
Hi, I had the same problem, MiMusic wouldn`t even recognise there was a disk connected although I could see it in My Computer.Found the answer on internet.
Attach it to your p.c. Then go to My Computer and highlight it. Right Click it and a box will appear . Go to FORMAT and format it. Another box will appear and ask if you really want to do it as data will be lost. Answer YES. Then format it. Disconnect from your p.c. Turn it on and you will be able to access the menu facility. Follow the instructions and goto CREATE LIB, BEFORE you put any music on to the thing.
I found it created library as soon as I disconnected it. BACK UP anything you have on it first as it will be wiped. It is working perfectly now and MiMusic is too. Yippee. Pat.
Jul 07, 2007 | Goodmans GMP33000S MP3 Player
Sansa e250 wont turn on
try undoing the back of it and take the battery out put it back in then try turning it on try it a couple of times this was only a temp fix for me
Oct 14, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
