Question about BenQ Computers & Internet
How can i download tha driver for LCD monitor Benq t902hda
alxz
  • 89 Answers
SOURCE: BenQ FP731 17" LCD Monitor Problem
Its a problem with the inverter. check the 4 transistors, C5707 near the connectors for the backlight. If none are defective, look for the PF751 FUSE. It sure to be busted.You can replace that with another 3A fuse. Remember, you should only replace the fuse if you are certain there are no busted transistors in the inverter board. Otherwise, you now have a refurbished Benq Monitor
Posted on Jan 07, 2008
myob247
  • 1342 Answers
SOURCE: how to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Posted on Jun 13, 2008
viziks
  • 220 Answers
SOURCE: Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
viziks@gmail.com
Posted on Sep 12, 2008
Geekman
  • 32281 Answers
SOURCE: LCD monitor display troubleshooting benq e900wa
Check the video cable, make sure it is not loose. Try the monitor on another computer to see if it works.
If not then follow these instrucrions :-
When the LCD monitor display is dim or flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 06, 2009
budmrtn
  • 11361 Answers
SOURCE: Benq 567s LCD monitor does not power up. Switch LE...
That cap is for the Primary power supply switching circuits. How is the DC secondary side, no blown fuse, shorted transistors in the inverter circuits? Pictures will help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
It may have the same bd as DELL since BenQ makes monitors for DELL and HP.
Posted on May 23, 2010
Benq t902hda
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Mar 11, 2014 | Computers & Internet
Cannot power monitor on.Takes at least 15 minutes keeping finger on power button before seeing Benq logo
It seems that the power needs a long trigger to get the pedestal voltage up to start the monitor. It seems tha fault relates to the main power supply and if you are equipped , then remove power plug, open panel and check on the capacitors on the power supply, check using a voltmeter the voltage build upp on trigger(+B) and how it taakes time to latch. Try and heat the section to confirm as it must start up immedialtely. If so replace the electrolytics on the SMPS unit.
Nov 07, 2011 | BenQ FP71G+ 17" LCD Monitor
I would like to download the SOUND driver for my BENQ FP72E 17'' INCH LCD SILVER.
dear not any driver required for any LCD so problem with your computer.
Feb 22, 2011 | BenQ FP72E 17" LCD Monitor
Benq T52WA LCD MONITOR SMPS OUTPUT VOLTAGES?
Hi
My Benq t52wa wide screen monitor works fine for some time and then its goes off for a few seconds and then comes back in regular intervels. This keeps on happening. Also im unable to get the auto adjusting thing that comes on the screen to go off. IT keeps adjusting.
I checked for the drivers and it says all drivers are up to date. Any suggestions please?
Feb 13, 2011 | BenQ FP553 (White) 15" LCD Monitor
I have an problem i am using your benq lcd monitor t902hd in xp service pack 3 but it is not able to find driver from cd plz tell me other source for download driver
1st download this driver and try http://ap.benq.com/page/?pageid=4&plid=5&pid=30000440&s=1
if same problem occers, then " check the cable connections both monitor and cpu , connect cable firmly.. best of luck . keep smiling
Jan 15, 2011 | Computers & Internet
Can not find a driver that is compatible with windows 7 for my BenQ FP2091 monitor...please help
go to the official website of the benq and then download the required drivers from there.....there is other option you can go for...
Oct 20, 2010 | BenQ FP2091 20" LCD Monitor
Where are the drvers for 22" LCD Mocitor G2220HD availble
Monitors do not need drivers. Sounds like an issue with your video card. The user manual for your monitor can be found here though
http://www.devicemanuals.com/guide/LCD/BenQ/BenQ-LCD-Monitor-G2220HD-User-Manual-English-==TXpFNE9UY3c=.html
crappy website but it offers .pdf type manuals for free. I tried it and it worked fine
Oct 02, 2010 | BenQ Computers & Internet
I have a brand new shiny benq v2210 but no drivers or install disk. How do I install it. t thanks
I just went to the BenQ website and found the following:
Please visit the BenQ website at www.BenQ-eu.com/serviceandsupport/ to download the appropriate LCD Monitor drivers, alternatively you can also use the standard plug n play monitor driver in windows.
First I did Google search for BenQ
> www.benq.com
> clicked on support
> chose USA
> Knowledge base
> FAQ LCD Monitors
> first question: I don't have the driver for my LCD monitor, what should I do?
Also, I found the BenQ phone number (1. 866. 600.2367) that you can call during Monday to Friday business hours which are: 8:30 to 5:30 PST
I hope this will help resolve this for you
cmilton111
cmilton111@gmail.com
Feb 26, 2010 | Computers & Internet
I need driver for BenQ joybook R43, where i can downloaded
BenQ's Technical Support Helpdesk (866) 600-2367
Their website is a bit to navigate and I was only able to find drivers for LCD monitors and projectors.
-=/ Daft Tech /=-
Oct 23, 2009 | BenQ Computers & Internet
Computers & Internet Logo
88 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
