You are either low on ink or the yellow cartridge is blocked. If you have a plug in the cartridge, doing a print head cleaning may help. On my inkjet printer, there are two levels of print head cleaning available.
Which brand/model printer do you have? Accessing the print cartridge level depends on the model and usually the software that you have installed. However, the software-provided level is an estimated level and may not accurately reflect the actual ink level in each cartridge. This is only available if you install the full-featured software from the manufacturer.
Generally, to see the estimated levels, if you have the full software installed, open the printer Toolbox. Then find a tab related to Maintenance and then get the estimated ink levels. For my HP printer, there is a specific tab just for the ink levels. (If you use Windows, there may be a icon for the printer in the notification area (on the right with the date/time information) that will let you open the software. Right click on the icon to access specific parts of the program.)
My printer has an option to print a quality test page in the Maintenance section which gives a better look at the ink levels. (For my HP inkjet, this is under the Device Services tab. Print head cleaning is also accessed here.)
Some printers with an LCD panel will let you access these maintenance items directly from the printer.
Please add a comment with your printer for additional information.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer thanreplace the print head.
You may need to run the maintenance processes such as head cleaning and alignment. It should be one of the tabs under the printer properties. Right click on the printer, choose printer properties, Maintenance. It depends from printer to printer. The alignment most likely is the culprit.
To check the ink levels ofyour printer
click on the start button of te computer and then click on control panel now go to printers and faxes open it and look for the name of your printer right click on the icon and go to properties
now click on printing preferences and then go to the features tab
in the features tab look for the printer service tab
now go to the estimated ink level tab and see the ink level
pls uninstall the printer driver from your pc, remove the usb core, turn off your printer and shut down your pc for about 10 min. then put on your pc reinstall your printer driver, if you have another usb cable change
Select Vista (or Vista 64-bit if you are using the 64-bit version) and download the appropriate drivers from there. These drivers should give you access to all of the necessary maintenance options including resetting ink levels (tell the driver you are installing new cartridges, remove and reinstall the existing cartridges to make it do the reset).
Test page coming out green indicates a problem with the ink cartridges since it should be using the black cart for most of the page.
So what you need to do is clean the cartridge from the printer toolbox..do all the three steps cleaning..(clean cartridge,prime cleaning,intermediate cleaning)..
once the cleaning is done..try to make a copy..if its still the same..change both the ink cartridge and then try to make a copy..if it resolves the issue then cartridge is defective..if it does not resolve the issue then printer is defective..
Try Cleaning the printheads. you usually have a utilitie to do this in :- Printer preferences. Also try several Print test Pages. It appears that your getting a surge of ink, at the initial printing stage. use standard paper to do all tests with. 1:- it,s cheaper. 2:- it,ll help soak-up any surplus ink. whereas the glossy paper does,nt soak it up too well. If these solutions don,t help. check HPs site for fault diagnosing and repairing.
Hope this helps you in the right direction.
Mike@Compurepair.
