Question about Symbol PDT 6846 Wireless Portable Terminal
Cold boot rqd. i can't downgrade. message appear error update cold boot rqd.
Here is the cold boot instructions:
To perform a cold boot 28, 38 and 48-key keypad configurations:
1. Simultaneously press and then release the 1, 9 and Power keys. Do not hold down any other keys or buttons. As the mobile computer initializes, the Symbol splash window appears for about a minute.
2. Calibrate the touch screen.
To perform a cold boot on 20-key keypad configurations:
1. Simultaneously press and then release the 1 and 9, MENU and FUNC keys. Do not hold down any other keys or buttons. As the mobile computer initializes, the Symbol splash window, appears for about a minute.
You may also need to download some software from Motorolla (depending if the boot fixes the issue).
Apr 09, 2014 | Zebra Symbol MC3100 Wireless Mobile...
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Should the return line come into drain of water heater or cold in.
Your question is not complete.
You have gas water heater in attic?
You are installing recirculation system? Which recirculation do you have? .. so expert can read instruction manual alongside you.
You can connect the recirc return line to the water heater drain valve only IF you have plumbed a separate return line for that installation.
Otherwise, the recirculation return line recirculates into the cold water inlet on water heater.
Copy following link for general illustrations showing both types of installation.
Aug 08, 2012 | Grundfos UP10-16BU/ATLC Comfort Series...
No wireless connection, wireless indicator not blinking, where can i send it for repair in the philippines
power on the router, connect the lan cable from the router to the pc. and wait for a while to if it wiil boot, if it does not come uo or boot return it to where you purchase it and get replacement of it.
Jun 13, 2011 | Computers & Internet
Can i run new hot water return line back to hot water system
Open following link to view how recirculation system looks:
Ordinarily the cold water line is used to complete recirculation loop.
There is no reason why you cannot run separate line back to water heater instead of using cold water line.
The Grundfos system comes with crossover piece that connects hot-and-cold lines at furthest faucet.
Instead of connecting between hot-and-cold line, simply connect hot to your new hot water return line.
When your new line arrives back at water heater, it must connect to cold water inlet so return water is directed to bottom of water heater.
For critical safety concerns, do not remove TP valve to install new water inlet.
Nor is it best to use extra plug on top of tank to install new water inlet, unless you also install dip tube that directs water to bottom of tank.
In the case of tankless water heater, return line must be connected to cold water inlet also.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
I have low pressure on my Worcester Bosch 30si but I can't remember how to fill it up, please can you help?
connect filling loop from cold main too heating flow or return you,ll find teed pressure system by short quick flicks at the valve on the cold supply best of luck
Nov 29, 2009 | Water Heaters
Usb cd boot
you need to set the boot device priority in the BIOS in such a way that the computer will take an external CD/DVD-drive as first boot device. to do this, you need to enable USB legacy support first, save and exit from the BIOS settings and then return to the BIOS to set the USB-CD/DVD-drive as primary boot device.
Jun 22, 2009 | Dell PowerEdge 2600 Server
Diference between Cold boot and warm boot
A warm boot restarts the mobile computer by closing all running programs. All data that is not saved is lost.
A cold boot also restarts the mobile computer, but erases all stored records and entries from RAM. In addition it returns formats,
preferences, and other settings to the factory default settings.
Apr 07, 2008 | Symbol MC1000 Barcode Scanner
Symbol PDT 6846 Wireless Portable Terminal Logo
170 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
