Question about Runco CW-50mc 50 in. HDTV-Ready Plasma Television
Runco compatibility with Apple tv hdmi video output
I have connected an hdmi to DVI-D single link cable into the dvi input 5 of the runco, but get no video at all. Apple tv outputs up to 720p, and runco claims 720p capability. I have wondered if a 24 pin DVI-D dual link digital only cable would handle the hdmi signal better for some reason, but hdmi to dvi-d dual link cables seem to be hard to find. Apple tv has no analog rgb outputs at all...hdmi only. Any suggestions?
Mark_Webber
  • 472 Answers
SOURCE: need a manual for 1998 runco 42''
If it is running in B&W, then you have got it set for NTSC and playing a PAL picture or the other way around.
Just go into the setup menu and the option will be there to set the video output format.
Posted on Apr 21, 2008
  • 3 Answers
SOURCE: PlasmaWall PL-61cx Runco; what's a 7 year old
Do you still have the tv? What happens when you try to turn on the tv, does it even turn on?
Posted on Jan 17, 2010
SOURCE: my runco flat screen all the sudden has a bunch of
did you ever find what the problem is my tv is doing the same thing....I have a runco as well and it is getting worse...usually after about 10 minutes it starts showing the picutre and the lines go away completely but, today I never could get the lines to go away...just wondering if you found an answer
Posted on Mar 19, 2010
  • 111 Answers
SOURCE: Runco DTV-5800-component to BNC connection problem
component cables have standard RCA fitting on the end. you can however but adapters enc to RCA. these work well are are readily available through eBay
Posted on May 04, 2010
  • 14 Answers
SOURCE: I need the power supply,
I have one. Call me at 630-416-2150. Kelly
Posted on Feb 28, 2011
I have a pioneer VSX-822k receiver. My older Runco CL-710 projector with DVI will not display anything from the Pioneer's HDMI output. (using a monoprice HDMI to DVI cable designed for this) The sourc
it is not compatable with 1080p,it says so on pg 17 of the projector manual,This unit is compatible with the following computer resoultions: 1280x720, 1024x768, 800x600, 640x480,you cannot use it with the receiver unless you use rca cables http://www.projectorcentral.com/pdf/projector_manual_2126.pdf
VSX 822 5 1 Channel 3D Ready Receiver
Oct 18, 2014 | Audio Players & Recorders
Hi,I have a XP-65DHD RUNCO PLASMA DISPLAY when I want to play a blu-ray movie on 1080p the screen starts flickering so I have to watch the movies on either 1080i or 720p,I really don't know what to do
If you got a blueray player (the hardware) it should have come with a disk with software. If you got the OEM version without, you need to buy your own software. PowerDVD should work. If you are somehow looking to download something to play bluray disks on a PC without an actual bluray player, you need to buy the drive.
Mar 21, 2014 | Runco CW42i 42 in. HDTV-Ready Plasma...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
On a runco cw50mc where does the satellite cable hook up on the back?
It doesn't. This is a "monitor". The best input for sat or cable TV is via the component (red, green blue) input or possible the DVI.
Dec 01, 2010 | Runco CW-50mc 50 in. HDTV-Ready Plasma...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Cant get hdmi to work
What device are you connecting to the TV? Are you using an HDMI to HDMI cable or a DVI to HDMI cable (or another adapter in the cable or between the cables)?
Try using a different cable. Try connecting the source device to another TV. Basically, you want to see whether the TV's HDMI input is bad, the device output is not active, or if the cable is bad (or an adapter attached to the cable is bad). Adapters are likely failure points. If you are using a DVI to HDMI cable, check your cable and device specs. Single-link and dual-link DVI are different and not interchangeable when attached to an HDMI cable end.
I hope this helps.
(some computers (esp. laptops) will have external video ports turned off by default and you need to turn them on before you try to send the output to an external monitor (TV).)
Apr 17, 2010 | Televison & Video
"invalid input" for hdmi
This model TV has specs for DVI, VGA, component video and S-video inputs. Are you using a DVI-HDMI cable? In that case, check your cable specs. DVI-I and DVI-D (single link and dual link) are not interchangeable and I would guess you have the wrong one connected to the HDMI for your unit.
I hope this helps.
Apr 12, 2010 | Olevia LT32HVM 32 in. LCD Television
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Runco CW-50mc 50 in. HDTV-Ready Plasma Television Logo
166 people viewed this question
Top Runco Televison & Video Experts
Carlos Oliveira
Level 1 Expert
Tom Chichester
Are you a Runco Televison and Video Expert? Answer questions, earn points and help others
