Question about Elite Sl 3000 Ul Sliding Gate Operator
Chamberlain plug-in transformerChamberlain Elite Roboslide plug in transformer has changed from a 18VAC output to a 24VDC output. There isn't any instructions with the replacement transformer. Whe
I replace the mothrboard on elite slidding gate but the batery loses power
Since you have a battery and it is a sliding gate, I will assume you have a Roboslide model by Elite. The battery has to be charged in order for the gate to work. The charging comes from a transformer or a solar panel. Check to make sure these have power coming out of them. Most gate operators use a transformer and if the two wires providing the voltage touch each other, it will blow the transformer. If you have a volt ohm meter you can check this. You might need to use the AC setting as well as the DC since some are 18 volt DC and others are 25 volt DC. You can do the same for a solar panel but only use the DC setting.
If this is not your issue, then make sure it is your battery draining and not something binding in either the motor or the gate. Finally, it could be the motor going out. Simply hook the charged up battery directly to the motor to check it. It should respond strongly. Reverse the leads to make the motor go the other way.
Good luck.
Mar 08, 2015 | Elite Sl 3000 Ul Sliding Gate Operator
How can i build a power supply s-0217d
You can build a similar powersupply using voltage regulators.
LM78M18,LM7818 78 for positive voltage(79 for negative) and the last two=regulated voltage.
connect them to the same transformer 18+2V(drop)=20VDC or > 14.2vAC.
So you will need
1:14.5vAC -18vAC transformer
2:Bridge rectifier or 4 diodes (schottky for efficiency)
3.The voltage regulators.
4.2 electrolytic 100uf-470uf capacitors per Vreg
5. one 100nf capacitor after each VReg in parallel with electrolytic.
Oct 24, 2014 | Audio Players & Recorders
Behringer eurorack mx 1604a
36V center tapped plus 48V phantom power, this is, 18-0-18VAC plus 0-48VAC transformer, this should be the correct voltages...
Sep 20, 2013 | Behringer Music
I I HAVE A philips 42pf5320/10 IT TURNS ON GREEN LIGHT IS ON BUT THERE IS NO BACK LIGHT, NO ONSCREEN DISPLAY, NO PICTURE.
Hi.
If your TV is LCD this are the procedure/steps to fix your problem.
Half picture on top of the screen, and the bottom half is black it means the back-light of your TV on the bottom is not working.
This are the step on how to find the trouble of your TV:
First, you have to remove the back cover of your TV to see the internal parts inside.
Secondly,after you open the back cover and the internal parts will reveal.Try to find where is the power supply board.It is usually connected to the power cord and it have a AC input that connects directly in you outlet.
It look like this:
This image is not exactly looks like your power supply because you don't indicate the brand name and model # of your TV.
Thirdly,plug-in the power cord then power it ON and be careful,check the output voltage of the power supply using a multimeter (range in DC) ,if it is have a 24vdc for the supply of inverter board.It is the board that gives a high voltage to the back-light of LCD TV.
Fourthly,if the power supply got the reading of 24vdc it means the power supply is good.Then try to check the input voltage of the inverter if it is have 24vdc.
The inverter looks like this:
This image is not exactly looks like your inverter board because you don't indicate the brand name and model # of your TV.
Fifthly, if the inverter have a input voltage please check the output voltage of it.It should have 500vdc so be careful to perform the voltage data in that point because it has a high voltage or hot area.
NOTE: if you don't have voltage reading on the input of the inverter board (24vdc) and the power supply an output of 24vdc,please check the wire that connect to each other.
Sixthly, If the inverter board have a reading of 500vdc on all outputs connectors (it is usually have 4 to 6 outputs).Your back-light lamp at the bottom are busted replaced it.
Or if your inverter board doesn't have a output voltage replace it.
You can buy the parts here:
Just click this direct link. http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=SFNT&Store_Code=EU
Or here:http://www.shopjimmy.com/
And also to eBay.com at your search engine.
Reminders:
If you don't have any basic knowledge about the electronics and testing equipment please don't attempt to do this steps.Its better to send it to the qualified technician or on the authorized service center of your TV.
If this solution will help you to fix your problem,please don't forget to vote and rate my answer.Thank you and good luck
May 08, 2011 | Televison & Video
My sanyo hdtv shows no pictures when you turn it on (the screen is black) but you can hear the audio. The remote control can change the channels and volume up&down but the picture won't show
Good day!
The problem of your TV could be the inverter board or the cold cathode light is busted.
Follow this instruction on how to fix that problem:
  1. Remove the back cover of your TV.
  2. Look for the Inverter board.
Inverter board looks like this:
3. Check the input voltage of the inverter board if have 24vdc.Using multimeter (range on DC)
4. If you have 24vdc,check the output voltage of the inverter board it should have 500vdc.
5. If you don't have 500vdc output on the inverter,replace it.
6. If the you have the output voltage on it,the problem could be the busted cold cathode light (C.C.T).Replace it.
I hope this solution will be helpful.Thank you and don't forget to rate my answer.
May 07, 2011 | Sanyo DP32648 32 in. LCD TV
Hitachi L26D103. Less than 2 years old. Working fine one day. Turned on the next day and the sound works, but not the picture. This is an issue when in both the TV and DVD modes.
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
May 06, 2011 | Hitachi L26D103 LCD TV
Hi.
It look like this:
Reminders:
I hope this solution will helpful.Thank you and good luck.
May 01, 2011 | Televison & Video
Charging LED does not light up. transformer send 19VDC to plug on board. battery drains
In my case, I solved this issue by replacing the Surge Suppressor. I was measuring 19VDC where the transformer connects to the surge suppressor but not at pins 2 and 4 on the connector to the control board. If "transformer send 19VDC to plug on board" means you are measuring 19VDC at connector pins 2 and 4 (or pins 2 and 4 on models that have a terminal strip instead of a surge suppressor), this answer doesn't apply.
Jan 11, 2011 | Elite Q206 RoboSlide Control Board
AC Adapter
I own one of these, which I bought new & hardly ever used. Still have the original packaging, paperwork, discs, etc.
The transformer (original) says this:
CLASS 2 TRANSFORMER
MODEL: 48A-18-900
UL LISTED 5J62
E113827
LR87815
INPUT: 120VAC 60Hz 25W
OUTPUT: 18VAC 900mA
9702
I hope this information is helpful.
Jan 28, 2008 | Micro Solutions -166550 External 8x CD-ROM...
Elite Sl 3000 Ul Sliding Gate Operator Logo
69 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
