Will not turn on
Hello
You haven't given the exact model number to your TV here. Anyway, check its mains fuse [can be located at its power regulator board] first. If it find opened, do not replace an other; without rectifying the fulat inside the power board. If protection fuse should blow up, surely there will be some reason for that, including short circuit or failure of components.
If you replace the fuse with an other one, the fuse that you will insert will also blow up, and may cuse more faults to other components. OK.
