Question about Sony RDR-VX500 DVD Recorder/VCR
I need the video only fixed on my unit and cannot find the part
The audio works as it is supposed to
  • W.J Richard Feb 12, 2012
    Where can I find the part?
  • 430 Answers
How do I fix my Changhong 49 Class Ultra HD LED TV? Model number UD49YC5500UA
Did you try to clear the memory and reset the unit to the factory default settings then re scan and reset your TV and Video settings
also have known of Set Top and Converter boxes going bad and only being able to receive audio through HDMI but get full video through component or S-video connection give it a try before you buy any parts !
Apr 18, 2016 | Ultra Televison & Video
Reciver Not Working.
A lot more information needed, please.
Brand, model number, what it is, what it's supposed to do (audio or video) - all that kind of thing plus age (not yours, the kit!)
Sep 20, 2011 | Samsung Audio Players & Recorders
My dvd player doesn't support wmv, avi, dat, mpeg, mp4 or 3gp. What should i do
This DVD player is supposed to support:
Supported Audio Formats Audio CD, MP3
Supported Video Formats DVD
Number of Audio Channels 4 Channels
Included Units In-Dash Player, In-Dash Monitor, Amplifier
Supported Media Types DVD-R, DVD-RW, CD-R, CD-RW
Monitor Size 6.5 inch
Touch Panel With Touch Panel
Just stick with these formats and it should work fine...are you trying to view burned movies or something. From the looks of it, it should play any DVD or CD just fine. Try to steer clear of those formats you listed.
Oct 18, 2010 | Pioneer AVIC-N2 Car DVD Player
How do I disable the parking brake feature for the DVD for a Boss Audio BV9978B
This is a feature which is a legal requirement by manufacture when producing unit, Driver is not suppose to watch tv while in control of a car.
Jun 22, 2010 | BOSS AUDIO SYSTEMS BV9978B Car Video...
Marantz sr5001 has pcm light flashing after child pushed buttons on front of receiver. no longer getting audio/video in tv mode but other modes are still working without issue. how can I get audio/video...
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Jul 25, 2009 | Marantz SR5500 Receiver
When unit is powered on it says check map disc??????
You need version 1.3 Map Disc in order for your unit to do anything. It is a safety feature. it is not gonna work at all I have the same problem. I need 1.2 Map Disc
Dec 29, 2008 | Eclipse AVN5500 Car DVD Player
Technics SA GX490 - Overload
yes it can be fixed , the input may have shorted and is now protecting the other circuits. it will need to be looked at and tested to make the repair. so calling and probably having to take it to, an electronic repair shop will need to be done.
Dec 07, 2008 | Audio Players & Recorders
I have a older sony STR-DB830 receiver that keeps blowing two fuses labled f801 and f802. They are 125v 8amp. They pop the instant you turn the power on. Something is shorted, but I can't find it. Is this...
hello, i believe that your problem is in the audio output ckt, check all the transistor you have one bad channel (shorted transistors). with a soldering iron disconnect them and check them with a meter.
good luck
caypianan@yahoo.com
Nov 10, 2008 | Audio Players & Recorders
Audio
Try if the Bose system have some setting need to be adjust or if your machine is configure properly on the audio section.Is a little bit hard to explain since is a step by step operation but check this two.Audio section on your ps3 and audio setting on BOSE System.Usually if the Bose Allow Direct setting use it.I had the same problem with a Onkyo receiver.Technology suppose to make your life easy but sometimes is complicate to understand.
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
No audio
There may be a toggle switch on the dash. siwtch it to on and tune into FM (88.7 or 89.1). Ours was 89.1. Hope this helps
Feb 24, 2008 | Audiovox MMDV2
Sony RDR-VX500 DVD Recorder/VCR Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
