Question about SanDisk Sansa e130 MP3 Player
Got stuck with broken display
It worked fine with a broken display ... i managed to get along although i have a problem with the instrumental being louder than the voice
now it got stuck when i pasted some different songs on it
i turn it on and it stays like that forever (untill now it stayed to check the playlist and then it was ok) but i waited for about 1 hour and the light was still on without letting me play anything (tryed quick format .. didn't work)
Try to open the case ..carefully and on the circuit board u can see a small battery soldered on it. you can try to disconnect one terminal ....and solder it again after 20 seconds , that can reset to default the settings.
Posted on Dec 16, 2008
Hi,2004 Rocket,6000 miles,riding along lost tacho,speedo,neutral light,indicator warning lights,although they still work,main beam warning light,bike starts&runs ok????
Hi, Nigel I would start at the instrument cluster wiring harness connector made sure you have no corroded, broken or loose pins/sockets and make sure there is a solid ground for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.triumphrat.net/sprint-forum/660602-speedo-tach-light-not-working.html
Speedometer not working sensor
Triumph Rocket III Service Manual
OEM parts for Triumph
Triumph Rocket III Owner Handbook Manual
Jul 04, 2016 | Triumph Rocket III Motorcycles
Someone help me?
pedal broken, stuck in closed position
Feb 07, 2015 | Yamaha Music
My bike kick stuck down while starting by kick. although eletic start is working fine what can be the issue ?
A broken lever return spring possibly. Use care around the kick starteri n that position especialy when shutting engine down.
Jul 23, 2014 | Bajaj Pulsar 150 Motorcycles
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 | Music
Stuck in park
is the jeep on a steep hill if so try rocking the jeep back and fourth while somone is inside trying to shift.
May 26, 2008 | 2004 Jeep Wrangler
Dim Display
On newer stereos, you might have to experiment with the "panel" wire.
I just installed a VR3, and discovered that the more voltage on the "panel" wire, the dimmer the display.
With no connection, you get full (daytime) brightness. With full voltage, you blank the display.
I wired mine up to the car's instrument lights through a 10Kohm trim resistor so I could adjust the "night" intensity. But if I dim the car's instrument lights, the stereo gets brighter. Oops.
Older car -- I can't just flip a software bit. ;)
But I gather a lot of new stereos are like this. The display on my (factory) stereo in the Mitsu dims a fixed amount when the lights come on, but doesn't adjust with the car's instrument dimmer.
Sep 23, 2007 | Car Audio & Video
SanDisk Sansa e130 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
