Receive error 0x00000057 with printer installation via USB with windows 7
After "succesfully" installing my printer (all diagnostics claimed it was successfully installed, as did the technicans I spoke with), I am unable to print. If I try to look at the printer properties, I get a prompt that reads, "The 'HP Photosmart 5510 series' pritner driver is not installed on this computer. Some printer properties will not be accessilbe unless you install the printer driver. Do you want to install the driver now? After selecting yes a trying to install the drivers from either the disk or the internet, I am prompted with: Unable to install HP Photosmart 5510, series, Type 3 - User Mode, x64 driver. Operation could not be complete (error 0x00000057). Also, I'm currently running Windows 7, 64-bit on my computer and trying to install my printer via a USB cable. I've run through all of the "simple" fixes on the phone with HP technicians, but they were unable to identify a problem. PLEASE HELP!
  • Emily L'Italien Feb 07, 2012
    I have previously installed the critical updates, uninstalled the software, and re-installed it. I have gone through all of the basic "fixes" that that the HP technicians have recommended. All of the HP Scans indicate that there should be no problem, but when it comes to printing I am still unable to do so. However, for some weird reason, I CAN scan....
  • 2,574 Answers
Make sure you have the latest service pack and critical updates for the version of Windows that you are running. To find recent security updates, visit Windows Update.Then re-install the printer's driver ..Download the driver for hp photosmart 5510 from the link below:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownload
Once you opened this page ..click the download button and save the file to your disk ..
Posted on Feb 07, 2012
Canon pixma ip4500 cannot install drivers, 'cause gives the error - "printer not detected", even though it's ON and conected to the PC.
Hello how are you.
If you install windows 7 when you turn on the USB cable to the driver you downloaded from the Internet.If windows finds himself then the problem is the USB turntable.
Call the appropriate Canon printer service.
Dec 16, 2012 | Canon Pixma iP4500 InkJet Printer
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
How to fix 0x00000057 error problems on windows 7
First of all update the drivers that control your PC.Fix registry errors.Scan PC with an updated AntiVirus.Use a system utility tool like Reginout for an instant fix.
Apr 19, 2012 | Microsoft Windows 7 Professional
Installed my Hp Photosmart printer c309a to a Toshiba (Windows 7) I am able to print wirelessly. But when i try to scan -"to computer" the screen on the printer reads !! Scan Problem-try...
Please install and run the below mentioned software to automatically diagnose and fix scanning issue:
HP Scan Diagnostic Utility
After installing this utility,
  1. Press the Power button to turn on the product, if it is not already on.
  2. From the Scanner column in the Scan Diagnostic Utility, select your HP product.
  3. Click Diagnose . The Scan Diagnostic Utility diagnoses various scanning problems, and then displays a list of results. The results display either when the tool detects an error, or when the tool completes the diagnosis and there are no errors.
    If this utility doesn't solve your issue, please revert back.
Sep 02, 2011 | HP Photosmart Premium C309A All-In-One...
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Epson sx515w wont fully install on my windows 7 laptop wirelessly
Look in http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/64f2f003-7c0b-4809-b376-e610b370fceb
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} "Problem getting wireless Epson SX515W connected to laptop running Windows 7"
In my case I had the SX515W configured via USB with other computer with Win XP, and later working by WiFi.
With may new laptop with Win 7, I have the error with the NetSetup installation CD.
First I checked that it was possible to print via USB with the laptop, and after I added by wifi using the "add new printer wizard" as explain Quagmire69 in the link attached.
Good luck
Jan 10, 2010 | Epson Office Equipment & Supplies
Device Driver Sofwtare will not install for HP
Hi, I have the exact same printer, with the same problem (Windows 7 Home Premium). Yes, the HP Windows 7 Software/Driver doesn't work for this printer.
But I was able to find a successful workaround. Follow these steps in Windows 7:
1) Click on the Windows Start Button and click on "Devices and Printers"
A window should pop up showing your devices and installed printers (if any).
2) At the top of this window, click on "Add a Printer"
A "Add Printer" dialog box should pop up with two options on what type of printer you want to install.
3) Choose the "Add a Local Printer" option. Ignore the small print under the option.
A window will now come up prompting you to Choose a Printer Port.
4) Choose "Use an Existing Port"
5) In the drop down box next to "Use an Existing Port", choose one of the USB ports. That entry should say something like:
"USB001 (Virtual Printer Port for USB)"
6) Click the "Next" Button
Now an "Install the Printer Driver" window should appear.
7) In the Manufacturer's Box, find and click on "Hewlett-Packard"
8) In the Printer's Box, find and click on "HP Deskjet 4200 Series"
9) Click Next
10) Follow the instructions on the screen to install. If Windows gives you the option to replace the current driver, then go with it.
11) Done! The printer should work. But everytime you plug it in, you may receive a notice from windows that the driver could not be installed. There are ways in Windows to hide that specific notice. But in any case, the printer should still print when you want it to.
Dec 02, 2009 | HP Deskjet D4260 Printer
1,063 people viewed this question
k24674
jasbo
jasbo
