Question about Bloomfield 8572 Coffee Maker
Bloomfield 8572 Leaking
My Bloomfield 8572 has begun a leaking problem. It first started leaking from the hot water dispenser on the front. I would just put a mug underneath, but now it has also begun leaking around the back underside. I'm not sure exactly where it is coming from. Any help on either leak would be greatly appreciated. Thanks in advance.
I just repaired my Bloomfield 8543 unit. I removed the top, by first removing the top rear 2 screws and unplugging the 2 heating element wires under it. Then mark all the wires that go to everything, (it is only a few) remove the center screw that holds the water tank lid brace down, slid the brace to one side (the groove on one side is longer) and remove the brace. (My brace was bent.) Then lift the lid (the heating elements will come with it) and clean the gasket. I went as far as to remove the tank, clean that as well as all the tubes. I tightened everything down and it worked perfectly again. Good luck, ken
Posted on Dec 02, 2008
Why is my bloomfield 8571 leaking?
Remove the top panel and check for scale on the liquid level probe. Remember to unplug the machine first.
Jul 15, 2014 | Bloomfield 8572 Coffee Maker
Bloomfield coffee maker won't brew hot water
Do you mean the machine will not heat up?
Oct 18, 2012 | Bloomfield 8572 Coffee Maker
I recently purchased a bloomfield 8572 on ebay and it is in pretty rough shape. i eventually want to hook it up to my waret line in my kitchen but my first test using the pour over didn't work. I...
You should contact Bloomfield to find your local Bloomfield Service vendor. You will need them for parts and/or service.
*** the following is for information only as all repairs should be performed by a qualified tech.***
The start switch activates the timer (analog or digital) board which turns on the water feed to the brew tank. This forces previously heated water out and sprayed over the ground coffee in the brew funnel. Coffee then drips into the decanter.
* But since the water line was not connected then the buzzing sound is just the valve opening.
* This brewer has a tank that needs to be filled PRIOR to powering up as the heater element usually turns on as soon as it's plugged in. The thermal fuse(s) will blow if tank is not filled. Once filled and powered up. Wait 20 mins then set up a coffee funnel and decanter. Slowly pour in 1 pot of water into the top opening. Do Not splash or over fill! Water should come out of the funnel and fill the pot (full). If it's not hot then the element is not working and this unit will need service.
* Check if there is an on/off heater switch on the back or side. (some are 'Vacation' switch) Turn on and wait 20 mins for another pour over brew. If it still does not heat then the limit fuse(s) are blown.
* Check the on/off switch. Most models will light up when switched on.
* Check the timer. Digital timers tend to be sensitive to electrical storms. Analog timers have a dial and are more tolerant of electrical surges.
* If you do get a good heated brew then continue to use as a pour over or hook up the water line to the brewer. (usually a 1/4" copper line with a flare or compression fitting.)
* Check the water fill solenoid. Should be a definite click when activated. Water filling sound should be very clear.
* No water flow then check the water supply line if it's on.
* Final; this brewer needs service. Call your coffee vendor for advice.
Aloha, ukboy57
Sep 26, 2017 | Bloomfield 8572 Coffee Maker
My 8572 coffee maker drips hot water ,even when no water is added to the machine.This is making it difficult to know how much water is needed to brew a full pot.
I will assume that it is a pour over brewer from your statement, so the only thing that comes to mind is the thermostat not turning off the elements and the water is boiling and coming out the brew tube. You can try to adjust the thermostat first if that does not help then you might have to replace it.
May 15, 2011 | Bloomfield 8572 Coffee Maker
My water doesn't get hot
you either have a bad thermostat, a wire off, or bad heating element. the heating element will burn out quickly if the pot is plugged in with no water, or if left unused for long periods of time. the water evaporates, and the element burns out. best thing is to remove top, and take a look.
Sep 26, 2009 | Bloomfield 8572 Coffee Maker
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Will not fill pot
Most likely you have some lime-scale build-up. When you brew a pot, it only brews the same amount of water that it takes in. When the inlet is restricted with scale, not enough water is let in for a full pot. You've adjusted the timer, so when you clear the inlet, you should set it back down so you don't overflow the pot.
It also could be just something cought in the inlet orifice (result is the same). Either way, start where the water is connected to the machine and go from there. Sorry I can't be more specific, scale is an elusive devil.
In the future, try using soft water.
Good luck
Mar 07, 2008 | Bloomfield 8571 Coffee Maker
Bloomfield 8572 Coffee Maker Logo
507 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
rhodesworks
EngineerMe
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
