Question about Singer Inspiration 4212 Mechanical Sewing Machine
Bottom tention thread loose
How can i ajust the tention the bottom thread is loose
  • Anonymous Mar 13, 2014
    i dont know how to get the tention write
  • Anonymous Mar 24, 2014
    tentioner came apart
  • Singer Master
  • 7,365 Answers
Try adjusting the top thread tension up one number till the stitches look normal
Posted on Feb 08, 2012
F2 is flashing and manual says call - I was turning material to finishing sewing bottom of pillow case.
Check the upper and lower threads are correctly threaded and check that the reverse stitch button isn't stuck in
Aug 17, 2010 | Brother ES2000 Computerized Sewing Machine
Hi, the tension on my sewing machine doesn't seem to be working. I have it all the way to 9 and the bottom stitch is still a little loose. Any advice?
Tensions on sewing machines really shouldn't be messed with at all, your problem is you don't have the machine threaded correctly nor the thread seated in between the tension disc. Turn your tention tunb back to between 3 and 4 and this should correct the problem
Aug 13, 2010 | Brother Sewing Machines
Loose stich on bottom of fabric
Hi. The problem is that your upper tension is too loose. It needs to be tighter in order to pull the bobbin thread up.
Robbie
Apr 17, 2010 | PfaFF Creative 7570
Stitches on bottom of fabric go from single thread to multiple and jam
this is a top tention problem. perhaps thread is not between tention disks
Apr 02, 2010 | Sewing Machines
I have a Singer 15-98 and the bottom thread keeps bunching up??? What might the problem be?
the top thread tentioner was too loose and the thread was not seated in it. It is sewing like a champ! Thanks
Oct 07, 2009 | Singer Sewing Machines
Needle timeing is out
The timing is set at the factory. If the threads are not hooking together, then perhaps try one of three things.
1. remove the thread, and run the machine at full speed for three minutes or more. This warms up the hardware, loosens gelled up oil, and get's all the parts in allignment.
2. (and 3.) Check the thread tentions. On the top thread, it will be a dial with numbers, over a spring and two plates that the thread runs through. On the bottom, it's a tiny screw on the side of the casing that the bobbin sits inside.
If the machine sews loose threads, then tighten these, a bit at at time, and if the machine jams up with a knot of thread at the needle, then loosen these. I believe that if the sewn threads are loose at the top, the bobbin tention neeeds tightening, and if the sewn threads on the bottom are loose, then the top tention dial needs tightening.
Cheers.
Aug 22, 2009 | PfaFF Creative 7570
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
White machine bobbin tention ajustment
how do you thread it ?can you give intructions?
Aug 11, 2008 | White Sewing 1521
Singer Inspiration 4212 Mechanical Sewing Machine Logo
107 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
