Question about Bose 701 Main / Stereo Speaker
Bose 701 wiring diagram - Bose 701 Main / Stereo Speaker
How do I get the wiring diagram for Bose 321 GS Series II Answer
If you're looking for a hook up diagram, look for it at the Bose website. If you're looking for a service manual, you may also contact them, but I doubt they would sell you one. If you're interested in having your Bose repaired, please visit my website at audioserviceclinic.com. You may contact me there. BTW, I was a factory authorized service center for Bose for over 20 years.Thank you.
Sep 04, 2015 | Bose Audio Players & Recorders
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
2007 Nissan Altima Stereo Wiring Diagram for Bose Navigation
None are actually color coded. The schematic has the wire colors on it next to the wire.
May 01, 2014 | 2007 Nissan Altima 3.5 Sedan
Does bose 701 series ii have a fuse for power subwoofer?
Fuses are used to control the inflow and outflow of electrical current. They are mainly used in speakers in order to protect them from being blown out. This is why there is a specific number of ohms on the instructions that it can handle. I'm sure there is somewhere. There are fuses in all high quality speaker systems. You'd just have to open the back up in order to find it.
Jun 18, 2011 | Bose 701 Main / Stereo Speaker
I want to connect my new amplifier bose ...., my car (audi a4 2003mod. ) have on the normal sound sustem with the concert audio..., i fix all the speakers from bose on my car and now i must put out the old...
Bose is premium gear at premium prices so it isn't wise to take chances - you should contact Bose to obtain a connection diagram and then you could find it isn't suitable to use the existing Audi wiring and you should wire afresh from scratch. Obtaining an Audi diagram will help or perhaps a connection diagram for the original sound system.
Sep 29, 2017 | Car Audio & Video
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
Bose 701 Main / Stereo Speaker Logo
197 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
