Question about Dometic RM2652 Refrigerator
Dometic rv refrigerator
Frig was working fine. After recall modification was performed (by a dealer) the frig won't work. There is no power light, auto light doesn't come on. Light inside the frig comes on when you open the door. won't work on gas either. Does anyone have any idea on what the problem could be?
  • Thomas3485 Jan 15, 2009
    I have the same problem as sallyfixit. Our Travel Trailer was taken to a dealer when we received the recall notice on the Dometic RM2652 refridgerator. When we returned from having this repaired, we didn't check to make sure the fridge was working. When we got ready to winterize everything, we checked and the refridgerator was not working. The off and on light was not working and the check light was not working, but the inside light was on. We have replaced the main power board and the eyebrow board and nothing is working. Now the inside does not even come on. All fuses are good. We need help.
    Pete
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Posted on Nov 11, 2008
Making the fridge work with eletric how do i do it
Posted on Apr 05, 2009
I was having the same problem as sallyfixit. After the recall on the Dometic RM2652, I was problem shooting to fix it. I found that you should check the wiring on the thermocouple to make sure it is wired correctly. If the on light, the check light and the interior light is still working but not cooling, replace the thermostor. This fixed my problem.
Posted on Jan 18, 2009
RM 2652 unit will not restart after running out of propane. Cannot hear the igniter clicking as when the water heater lights.
Posted on Aug 17, 2011
I have a Dometic RV frig and a week ago it started to smell of spoiled dairy. I cleaned every surface and checked all the refrigerated products, but the smell continues and is getting worse. Please
My rv refrigerator doesnt have a drain but I do know how to get stink out of a refrigerator providing everything has been wiped up. My freezer at home was accidentally unplugged for weeks with two bears and half a deer in it. Life altering stink ensued. I tried every kind of cleaner and procedure including running it with charcoal briquets in it. Nothing worked and I was getting ready to throw it out until I was told to wipe it down with vanilla extract. It worked immediately and has been fine ever since. Cheap and easy.
Jun 10, 2017 | RVs
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Oct 11, 2013 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Dometic 2652 runs sparatically, then quit
If the burner area is geting hot its has a leak
Dec 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerator not working
LOWER CIRCUIT BOARD
The controls for Models RM2612, RM2812, RM2652 and RM2852 are unique to these models. They
are NOT interchangeable with any other models.
If you suspect mismatched part numbers, compare the part numbers on parts to the ones listed below
to ensure a proper match.
The RM2612 with Serial Number 41900000 or higher will have Version III controls as original
equipment.
The RM2812, RM2652 and RM2852 should have only Version Ill controls as original equipment.
VERSION I
Display Panel 2932189.01
Power Module 2931842.02 or 2931842.03
Thermistor 2931863035
VERSION II
Display Panel 2932189.02
Power Module 2931842.02X
* Power Module has red plugs and a Red Dot on
the cover.
VERSION Ill
Display Panel 2932189.03
Power Module 2931842.04
Oct 03, 2008 | Dometic RM2652 Refrigerator
Dometic frig 2852
There was a recall on the frig by Dometic.
Aug 28, 2008 | Refrigerators
Dometic RM2652 Refrigerator Logo
943 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
