Question about Chevrolet Chevy Silverado Extended Cab
HELLO I'M MARCO AND I HAVE A 2000 CHEVY SILVERADO, I HAVE PROBLEMS WITH AIR CONDITIONING CONTROL STAYED IN ONE POSITION
  • Chevrolet Master
  • 5,370 Answers
Click this link below for all types of car AC problem,solution:----
http://schematicsdiagram.blogspot.com/2012/01/ac-problem.html
Thanks.
Posted on Feb 07, 2012
AC blowing hot air one side & cool air other side
If it has dual zone temp. control it is most likely the heater control panel.
Jun 01, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
On my sons 2000 chevy silverado 4.8 liter....the heater works fine....but when i switch control to defrost....only cold air blows out defrost vents....any help would be appreciated.
the heater & defroster baffles are controlled by electic motors that open and close the baffle (doors) to let the air to the heater and defroster vents. the motor must be bad
Jan 12, 2010 | 2001 Chevrolet Silverado
2005 chevy 2500hd duramax driver side vents blow hot air
It sounds like the HVAC head needs to be recalibrated, most likely when you unhooked the battteries you lost the memory to the control head, it's in a default position/state.
Aug 21, 2009 | 2003 Chevrolet Silverado 2500HD
Air conditioning silverado
The problem is in the heater box. To be more specific, the blend door. Check blend door operation and blend door motor. Located right side under dash. Remove blend door motor, with vehicle running, move switch from panel to defog and see if blend door motor moves.
Jul 25, 2009 | 2005 Chevrolet Silverado
1997 chevy silverado 1500 350 vortech, new fule pump not working
before you drop tank again, check fuses & relay.then disconnect fuel line @ filter turn key to on position should hear fuel pump run and get gas stream out of line. if no flow from line new pump faulty be sure & remove negative battery cable first good luck.
Jun 04, 2009 | 1999 Chevrolet Silverado 1500
A/c problem
Air Conditioning Belt
  1. Remove the accessory drive belt.
  2. Raise and suitably support the vehicle.
  3. Remove the engine shield bolts.
  4. Remove the engine shield.
  5. Install a ratchet into the air conditioning (A/C) belt tensioner adapter opening.
  6. Rotate the A/C belt tensioner clockwise in order to relieve tension on the belt.
  7. Remove the A/C belt from the pulleys.
  8. Slowly release the tension on the A/C belt tensioner.
  9. Remove the ratchet from the A/C belt tensioner.
  10. Clean and inspect the belt surfaces of all the pulleys.
    0900c1528024920d.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Location of air conditioning belt tensioner-4.8L, 5.3L, 6.0L Engine
Apr 08, 2009 | 2000 Chevrolet Silverado 1500
Chevrolet Chevy Silverado Extended Cab Logo
246 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
