Question about Compex Computers & Internet
How to turn off the router's firewall
Hi
I am trying to connect to programs like emule, and it says that the firewall is on. I am turning the Norton's firewall off, but still get the same result. I understand that it may be the router's firewall... How do I turn that off?
My router is Compex Netpassage 18A.
Thanks a lot!
Yaron
    Scholar:
  • 87 Answers
1. Insert the Product CD into your CD-ROM drive. The CD will run automatically.
From the Utilities section, select to install the uConfig utility to your hard disk.
2. When the utility has been installed, double-click on the uConfig icon. The
following screen will appear, click on the Yes button to proceed.
3. Select the router from the products list and click on the Open Web button. To
retrieve and display the latest device(s) in the list, click on the Refresh button.
4. Do not exit the uConfig program while accessing to the web-based interface.
This will disconnect you from the device. Click on the OK button to proceed.
5. At the login page, press the LOGIN! button to enter the configuration page. The
default password is “password”.
6. For the first time login, you will be prompted to select your time zone setting first
before accessing the router’s main web page. Take note that during the next
and subsequent logins, you will not see the System Time Setting page again.
7. You will then reach the web page of your router’s web-based interface.
8. Under the SECURITY CONFIGURATION command menu, click on Firewall
Configuration.
Posted on Oct 22, 2008
No internet connection after uninstalling norton
hi there.
you could try and do a restore to the last date it all worked fine.
or see if starting up in safe mode might help you find out.but i would try the restore first.
Nov 17, 2017 | Norton Internet Security 2005...
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
Skillground error 357
i've tried (for several days now) to download the software, but everytime i click "download & play" nothing happens
(it looks like the 'page' just keeps refreshing it self for several minutes, ending in a "error code 357" message!
I contacted skillground numerous times , and thou they are helpful in their replies.. they keep saying that its my router and/or firewall that prevents the software from downloading.. BUT
even when i disable the router (running the internet cable direct from the "wall plug" into my pc) , and disableing my firewall (Norton) (i have even tried uninstalling the Norton).... its still the same problem
I've allowed cookies... set the internet security to minimum ..disabled the router and Norton firewall, ..removed the skillground 'program' and even tried to create another account ...but its still the same problem ... so i've ran out of idea's
but have you tried checking (in addition to your router, and norton firewalls) the built-in vista firewall?
May 04, 2009 | Computers & Internet
Disabling the firewall?
You have to know the required ports for music downloading in order for you to configure on your router.
Mar 01, 2009 | Westell Wirespeed ProLine 6100 Router...
My Acer Aspire 5100 running on Vista will not connect to the internet. This went bad after a support session Norton trying to re-install Norton 360. They ran me through numerous steps, steps I can't...
disable the norton and pc or laptop firewall disable it then try to connect then you connect it then you on your norton and the firewall ok only onces time you have to disable
Feb 21, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Firewall
You may find out that Norton is causing the block and not the firewall. To disable the Windows firewall do the following:
1) Click on Start then control panel
2) Click on Windows Firewall
3) Click on the Exceptions tab and see if Windows Live is listed and checked.
4) If not, click add program and add Windows Live
If it is there and checked then you can disable the firewall by clicking on the General tab and selecting Off from the firewall screen.
4) Finally, click OK
If none of this works then try turning off Norton. If that lets you log in then you will need to add Windows Live as an exception to Norton.
Good luck
Feb 17, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Router F5D82314 worked fine for a year, now will not allow desktop or laptop to go to links from homepage
Hi!
Can you describe your setup in a little more detail, please? What OS's are on your computers, what firewall and Anti-virus programs are on the computers, and especially did you change anything else at about the same time that this problem started?
The easiest way to determine if a firewall is the problem is to turn the firewall completely off and see if the problem goes away. If it does, you then know that you need to configure that firewall so that it will work properly in your environment. If I were to venture a guess (which could be totally wrong), a firewall on your computers (like one that is installed as part of a Norton/Symantec program, for example, even if the program isn't labeled as a firewall) is in conflict with the router's firewall.
Please let me know if this helps and good luck!
Bob
Oct 08, 2008 | Belkin (F5D8231-4) Wireless Router...
I need help connecting t o the internet
there are several issues that could lead not being able to connect to the internet. it can be a router problem if you are networked. it can be the ethernet card. it can be that you internet explorer is corrupted, it can be that you have an invalid ip address, it can be due to firewall. if you have a norton or mcaffee antivirus program the firewalls of this program can prevent you from getting online. or some updates from norton or mcaffee will knock off your internet connection.
try going to safemode with networking in the advance boot menu (normally if you press f8 when your computer is turned on) if you can go online in safemode with networking it means a program is causing you not to connect.
worst case scenario: REINSTALLATION OF WINDOWS
Jun 19, 2008 | Computers & Internet
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Oct 06, 2007 | D-Link DI-707P Router (DSDLDI707P)
Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Jan 20, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Computers & Internet Logo
356 people viewed this question
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
