Question about Bissell Cleanview Helix Deluxe Bagless Upright Vacuum Cleaner 21K3
Turbo brush on bissell cleanview helix stopped spinning
My Bissell Cleanview helix turbo brush suddenly stopped turning, and the vacuum is only months old. There is suction coming from the hose and the attachment is firmly in place. After reading other comments, I took apart the brush and fully cleaned it. The belt seems to be in perfect condition and I WD-40'd the heck out of both the brush ends as well as the ends of the "fan". I'm baffled.
    Master:
  • Bissell Master
  • 851 Answers
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Aug 06, 2017
3 Suggested Answers
  • 17 Answers
SOURCE: bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Posted on Jul 07, 2009
  • 903 Answers
SOURCE: the turbo brush attachment on
The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
Posted on Apr 07, 2011
How do I clean the filter
The foam filter can be hand washed, squeezed and them dried.
The pleated filter really never seems to loose it stall smell after cleaning. It's best to tap it against the hard ground to free the dirt.
Washing it can cause odors.
Sep 27, 2014 | Bissell 2 Sets Bagless Upright Vacuum...
Hose won't ****
If the hose has no suction but the suction is good at the floor it is probably a clog in the hose or one of the tubes.
Mar 06, 2014 | Bissell Cleanview Helix Vacuum
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
The turbo brush attachment on my bissell cleanview helix suddenly wont spin. I bought this vacum a month ago. there is nothing wrong with the vacum otherwise.
Feb 04, 2011 | Bissell Cleanview Helix Deluxe Bagless...
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
My bissell helix cleanview vacuums brush doesn't spin
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
The vacuum was working fine then suddenly the main brissels that spin to collect the dirt stopped spinning, the vacuum still has suction but barely picks anything up because the brissels are not spinning
Best thing to do is remove the spinning brush and clean all debris from the brush and most importantly from the ends of the brush. The ends of the brush usually have two holders (square?) that hold the brush in place on the vacuum. The brush is supposed to spin in these holders. If it does not, provided the belt is okay, the location where the brush contacts these holders need to be cleaned and lubricated with some WD40 or some 3 In 1 oil. Be sure the belt is in proper running condition as well.
Sep 05, 2010 | Bissell Cleanview Helix Vacuum
I have a Bissel Cleanview Helix, model #82H1. The
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell Cleanview Helix 82H1 Series User Manual
Ava B.
May 29, 2010 | Bissell 35755 CleanView Bagless Upright...
Bissell Cleanview Helix Deluxe Bagless Upright Vacuum Cleaner  21K3 Logo
387 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
