Question about NetGear WGR614 Wireless Router
Intermittent loss of internet cnnection.Very annoying!
As above,I keep losing internet connection intermittently which is very annoying.My computer "dongel" attachment is only about 9 metres from the router in another room.Interestingly the blue light on the dongel flashes and is not constantly on.HELP please.
  • 4 more comments
  • robert693 Oct 22, 2008
    Willing to try your suggestion of new dongle,or even new device-all under guarantee so worth a go.
    Many thanks for helpful remarks,and speedy service.Will get back to you with results-THANKS.
  • robert693 Oct 26, 2008
    Thanks for all suggestions.Took dongle,usb connection lead and netgear router back to PC World-very helpful technical staff checked everything including incoming BT line for strength/tree branch interference in wind -ok.
    Moved router to a different site,still in the original room upstairs,but away from bedside radio/clock/alarm and the bedside lamp;positioned dongle to full length of usb cable vertically above PC--PROBLEM SOLVED.
    Question : Is the workings of routers interfered with by other electrcal equipment in close proximity?
  • Anonymous Dec 13, 2008
    Same proble, router needs to be restarted 2 or 3 times a day - linked to Virgin broadband 10mbline with little volume.
  • garobi Jan 27, 2009
  • roskya320 Feb 09, 2009
    My motorola sbg900 wireless connection seems to disconnect randomly with my desktop connected via an ethernet cord.With the ehternet disconnected, my wireless remains connected without random interuptions.
  • CS-Vicky May 11, 2010
    Have you tried a different wireless dongle/other device?
I have the same router - but its all connections that it loses not just wireless. Every 15 or 20 mins I get kicked off of World of Warcraft (wired connection) and my son gets kicked off of COD4 (wireless PS3). So it's def the router thats at fault. Looked for new firmware but its got the most current.
Posted on Jun 03, 2009
  • 70 Answers
Yep, microwaves will give them hell as they work along the same frequency. Ours used to switch our wireless on and off whenever my mother was cooking. Much fun, I can tell you.
"Mam! You've killed the net again!"
What I did do as a temporary solution when I had similar problems is make a small satellite dish out of foil for my dongle.
It may be worth investing in a router with more powerful wireless. There's some 2-Wire routers also sold as BT Home Business Hubs which have stronger wlan than usual. They tend to cost more but they're worth it. Really good routers too, especially if you have a weak line.
Posted on Oct 27, 2008
  • 56 Answers
Sounds like it might be a bad USB dongle causing the problem. Have you tried another USB port on your computer to rule out a faulty dongle?
The other problem might be a faulty CAT-5 cable. Make sure that the cable is not be stepped on or rolled over by a chair. It is very easy to break the wires inside the cable and still get connections off and on.
Check these solutions and let me know your results.
Posted on Oct 23, 2008
I am not connected to wifi all the time it cuts out
The following site mentions several factors that may be causing intermittent connection. I suggest you fix the ones that may be fixed. Check what may be checked. Some may not be fixable.. Is your intermittent connection experienced more often than not in a particular environment? Does that require you be blogtcked from a direct line of sight to your router? Is the blockage, if present, significant in terms of wiring or electronics.
Loss of Wifi Connection High Speed Internet Customer Service Verizon
Sep 14, 2017 | The Computers & Internet
Intermittent Sync and you: What does it mean?
Intermittent sync is the signal from your DSL, Cable, or Fiber service provider's Central Office (CO) to you losing connection every now and then. Now, with DSL, this also includes low bit rate (where the modem throttles the connection to try and maintain the connection), intermittent route (you can't get online if there is no signal!), and slow throughput/ packet loss. <br /><br />With Fiber, it can mean a damaged fiber optic cable, or potential area outage. <br /><br />Cable does not usually experience low bit rate/ intermittent sync like DSL, however it does have some similarities since Cable does run (at least a portion of the cable!) on copper cabling. <br /><br />Intermittent Sync can be an area issue, however usually area issues are no sync or no route- not the intermittent problems<br /><br />Now, an intermittent issue is hands-down the most annoying of connectivity problems since sometimes it works, sometimes it does not. <br /><br />How do you troubleshoot intermittent sync? <br /><br />Depending on your connection type, you may need to isolate the connection. What this means for DSL is if you have a phone, a fax, and a credit card machine on the same telephone line, you need to see if the intermittent issue clears with those devices off the line. Other factors for DSL intermittent sync is distance from the CO, age of the modem, issues on the line, and problems within the CO<br /><br />If you have noise on the line- it could either be the modem or something within the cabling or CO. <br /><br />With Cable, isolation is not so much of an issue- although they may ask you to remove the cable boxes temporarily till they can verify the issue is not interference from a defective cable box<br /><br />Fiber (FIOS) is unique that intermittent sync is not really caused by issues w/ the wiring of the building- report to technical support immediately if you have intermittent connection issues with Fiber.<br /><br />All of the above issues need you to contact tech support when you have time to do basic troubleshooting steps. However some legwork can make this process easier.<br /><br />Write down when it goes down- if there is a pattern to when it goes down, it can help narrow down WHY the problem is occurring. For instance, a person had service go down after 9am every day and when it was raining. The issue was caused by construction breaking the underground cable casing- and after the sprinklers ran at 9am sharp- the water would get into the casing and short the person's connection! <br /><br />A log of what happens with the problem not only helps you- it helps you help the technician! If you can pick up on the pattern- it narrows the possibilities of what's causing the issue. Any way of narrowing down the problem means you will have your service restored that much faster.<br /><br />If it requires multiple repairs- that log will also help in narrowing down what's left<br /><br />For packet loss/intermittent route- record what sites have the issue and when. Again, the pattern helps troubleshoot the problem.<br /><br />Do not demand for a technician at the location- often the problem could be in the CO- sending a tech only delays getting to the right spot to fix the problem<br /><br />If your connection goes down- the MOST important thing to do: Report it. With intermittent issues, the more documentation, the better. <br />
on Jan 09, 2011 | Computers & Internet
I have a 01dodge RAM 1500 and the oil gauge keeps going from 40 to 0 and the check gauges light keeps coming on but I checked the oil and it's fine, what could be the reason for this
1. You need to have an independent oil pressure gauge hooked up to the engine to check the oil pressures at various RPMs and to verify the 40 to zero drop. This will eliminate any issue with the pressure gauge or the sending unit.
2. The oil pressure variation can be caused by an intermittent blockage in the oil pick up or an intermittent sticking oil pressure relief valve. I would possibly suspect the latter if you are getting good pressure and it is intermittently dropping to zero and going back up again..
If you or previous owners have not maintained the engine with frequent oil changes you will get a sludge build up problem in the engine and this will be evident by just dropping the engine sump.
3. If you have had a check engine light warning then you need to have the vehicle scanned to see what fault codes have been generated by the computer. There will be some related to the intermittent loss of oil pressure but there may be others also..
4. You need to have the oil pressure problem checked out immediately. Running the engine when you constantly lose oil pressure intermittently will definitely cause engine damage due to a loss of both lubrication and oil cooling to critical components.
Apr 01, 2016 | Cars & Trucks
Lose internet connection
Which type and brand of router ?
Several computer models include two specific hardware components that enable the device to connect to the Internet: an Ethernet adapter card and a wireless adapter card. These cards are also called network adapters, or network cards. If your computer suffers from an intermittent Internet connection, and your Internet service provider (ISP) doesn't detect any issues on their end, you can update the software for the network adapters to resolve the intermittent connection. If updating the adapters doesn't resolve the problem, reset the transmission control protocol/internet protocol (TCP/IP) and Winsock to restore the connection.
Click "Start." Click "Control Panel." Type "manager" into the search bar. Click "Device Manager." Expand "Network Adapters." You should have one wired adapter and one wireless adapter, if the computer has wireless support. Double-click each adapter. Write down the name of the adapter, as well as the manufacturer's name. Go to the computer or network adapter manufacturer's website if you installed the adapter to the computer yourself. If the adapter came with the computer, go to the computer manufacturer's site instead. Select the "Support," "Download" or "Drivers" page. Look up your computer or adapter model. Select your operating system. Click the "Network," "LAN" or "Internet" category. Download the latest adapters for your network devices. Click "Save" or "Save As" and save the files to your desktop. Return to Device Manager. Right-click the first device. Click "Update Driver Software." Click "Browse My Computer for Driver Software." Follow the remaining on-screen directions to reinstall the device driver. Repeat the process for the other network device. Restart the computer after reinstalling the drivers to repair the intermittent Internet issue. Reset IP Log in to Windows as an administrator. Hold down the Ctrl, Shift and Esc keys to open Windows Task Manager. Click "File." Click "New Task." Type "cmd" and press Enter to open Command Prompt. Type "netsh int IP reset c:\resetlog.txt" into the Command Prompt. Press Enter to rewrite the TCP/IP registry keys. Enter "netsh winsock reset" into the command-line prompt. Press Enter to reset the Winsock catalog and resolve the intermittent Internet problem.
How to reset Internet Protocol (TCP/IP)
Apr 18, 2013 | Computers & Internet
My modem keeps dropping connection. I have called my ISP and they say everything is running just fine. It happens when i am playing counter strike source and i start lagging badly and all of the sudden my...
Intermittent connection issues are very difficult for internet service providers to trouble shoot. The first step in trouble shooing any Intermittent connection problem is to look at the chain of equipment involved in flow of data from the internet service provider to the end user. In most homes the packets enter from the main line to the modem, than from the modem to the router, and finally from the router to you computer. So that means that the issue can be caused from the following equipment: main cable line, splitter, modem, router, or the Ethernet / wireless card of the PC. The first step in trouble shooting this problem is to wait for the internet to drop off. As soon at this happens go to your modem. If the top 4 lights are not solid green then the the modem is losing it's connection to the internet. This can be cause by some thing as simple as a bad splitter in the home or some thing as complicated at an issue at the pole. If the modem drops the connection I would recommend contacting the internet service provider and demand a service call to swap the modem and check the pole. Now if when the connection drops the modem still has access than the issue is most likely with the router or PC. If more than one computer loses it's internet access than you can rule out the computer as the issue. At this point I would have to recommend bypassing your router for about 48 hours. If the issue does not return than you know the router was the source of the problem.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
My harmon kardon av amp keeps losing its memory/settings when its switched off, it also loses audio on the 3/2/1 on the aux, dvd channel, intermittent loss of volume help, too good a system to bin thanks
could be the memory chip, I used to see this a lot with Panasonic tv's that would lose all memory settings ie channel and tuning memory, with the intermittent vol problem it sounds like dry joints in the amp section, always check the components around the heatsinks for dry joints, especially capacitors and transisters, pay to get your hands on a service manual showing all the layout and different componets.
May 30, 2010 | Audio Players & Recorders
2004 RX 330: intermittent power steering loss, hard to turn, so...
I think you may have a problem with your electric assisted power steering motor. Is the loss in power only when your are making sharp turns to the right or left?
Do you hear any load noises or squeling sounds?
You should have it inspected, Don't want you to lose control while driving.
May 16, 2010 | 2004 Lexus RX 330
Spontaniously lose internet connection to status "limited or no connectivity" intermittently and have to reset and reconfigure. this can be after 1 hour of use or several days
We have solved our wireless connection loss by connecting the Hawkings by cable to the first computer needing a signal from it a second computer is able to connect to it OK, these two computers are upstairs and the main computer with router is downstairs this is working OK at the moment without the frustration of losing the internet connection
Jan 05, 2010 | Hawking HWREG1 Repeater
NetGear WGR614 Wireless Router Logo
1,002 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
