Question about RCA 32F531T 32" TV
Clicker limits I can click up one channel at a time, till 39. Then I have to enter each station above that on the number keypad.....
  • 899 Answers
Rca is known for needing new solder jobs and mostly in the tuner area and power section
so it is most likely the the tuner section and probably the power section should get the new solder job done or the tv will start to have a life of its own!
I have a rca 27v412t that started the same stuff but I resoldered and it lasted about 7 months before I had to do it again
and if after that it don't recieve certain frequency's it may need a new IR sensor and possibly a crystal and EEPROM chip as well
electech
Posted on Oct 22, 2008
How do I reprogram a Clicker Product wireless keypad (model Number: KLIK2) for a chamberlain opener. It has a smart button on the opener.
It is a pain in the b---. Follow the instructions given for your chamberlain opener (correct color memory button), install a nice new hot battery and keep doing the deed till you get it to work!!!!!!!!!
Apr 05, 2015 | Building Materials
I want to reprogram some numbers on AT&T 822 (21213)
1. Lift receiver, touch "program" (above number keypad, on the bottom left of programmed numbers).
2. Enter phone number (1-AC-Number).Touch button for quick dial station (e.g., Name of Person to Call).
3. Hang up phone.
4, Lift and touch programmed button to dial (new) number.
Oct 06, 2013 | Lucent AT&T Speakerphone 822 (21213)
How do I program a uniden BC 145xl base scanner
  • Press the power button to turn the scanner on.
  • Press "MAN" (for manual)
  • Now pick a channel where you want to store a frequency at and enter it on the keypad.
  • Now press the "MAN" button again to go to that channel.
  • Now enter the frequency you want into that channel and don't forget to include the decimal point.
  • Now press the "E" button (for enter) and you have programmed one frequency.
  • Repeat these steps until your scanner is programmed.
  • Now you can press the up and down arrow buttons to scroll manually through the channels or just press "scan" to scan through them.
  • Make sure to keep your squelch just above the noise so you pick up stations well.
  • Hope this helps.
Nov 24, 2011 | Uniden Radio Communications
Problem with tuner can't get upper channels. have tm before channel number.
You usually need to do a channel search maybe every month or so. Sometimes your local cable company moves stations to add others. Also you may want to scan at different times of the day due to whats floating around above your house. Hope this helps.
May 29, 2011 | Televison & Video
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
I lost the user manual for my ICF-SW30 SONY radio.
tune to station you want preset; hold down Enter/Time button while you press the number you want the station to be on the keypad.
Nov 28, 2008 | Sony ICF-SW30 Radio
Window media player11 in vista
you can try it this way
  1. Go to the start screen by selecting the mcestart.png button within Windows Media Center.
  2. Scroll to Online Media, then click on Program Library.
  3. Click on Music and Radio, and then continue to click on More Music and Radio to see a list of radio stations available.
  4. Click on the station you want to listen to, and it’ll begin streaming through your Windows Media Center display.
or you can try this
  1. Go to startmenu.png Start, All Programs, then click on Windows Media Center.
  2. Select Music, then scroll across to Radio then click on it.
  3. If you know the number for the station, enter it into your keypad then press Enter.
  4. If you don’t know the number for the station, select the + and - under Seek and Tune to find your station.
Dec 18, 2007 | Microsoft Windows Vista Ultimate Edition
RCA 32F531T 32" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
