Question about Canon PIXMA iP4000 InkJet Photo Printer
PIXMA Ip4000 When I print with blocks of color, the colors appear striped. When I do a nozzle check, everything is find except the dark magenta strip is two-toned, dark on top half and light on bottom half. Do I need a new print head? I have tried multiple deep cleanings, etc.
  • ddamen
    ddamen Nov 10, 2008
    I am printing on plain paper and my printer is set for plain paper. I have had the printer for a few years (4 maybe) and it will probably cost less to get a new printer instead of sending it in for repair.
    I appreciate your suggestion, I'll keep it in mind for my home printer. This is my office printer and it works good for text which is its primary use. Thank you.
  • oddpod Dec 10, 2008
    I have a very similar problem but for me it is the blue which appears to be two-toned and there are stripes appearing in the blocks of colour. For me this seems to have nothing to do with the paper type. I have the problem with photo paper and plain paper. I have tried deep cleans, normal cleans, auto realignment, and even physically cleaning the heads (though only very gently).
    Any suggestions?????
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Posted on Nov 05, 2008
No red color appear when i print pictures
The Magenta print head nozzle maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 08, 2013 | Canon Pixma iP2700 InkJet Photo Printer
Doesn't print magenta?
It appears the magenta print head nozzles are blocked.
Apr 06, 2013 | Kodak ESP Office 6150 All-in-One Printer
My Canon MP980 Print/scan/photo Series printer is printing everything that is in color in yellow. I have cleaned the heads & nozzles. What is wrong?
Causes : Blocked by dry ink. Solution : Your Color i.e. Cyan & Magenta were malfunctioned/blocked. So try to clean them up tightly.. thanks
Sep 02, 2011 | Canon PIXMA MP980 All-In-One InkJet...
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Nozzle check wrong, but no clogged printhead
on an i960 canon the magenta does not come through/thank you,Leo
Feb 17, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer problem
Hi , did you check nozzle what color appear , some ink cartidge are old stock and dry , pullout cartridge clean the contact nozzle .
Feb 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with color quality - Canon PIXMA iP4000
i had this problem... its the ink! Check you are using magenta and NOT "photo magenta", and also that you are using "cyan" and NOT "PHOTO cyan"... basically photo cyan, photo magenta and photo yellow are not designed for the ip4000, if you check the smallprint on the box it does not list the ip4000.
This exact problem happened to me and it was driving me crazy. I think the "photo" versions of the inks are for printers that take two tanks of each colour, and the photo version is used for very subtle colours... so if you are ONLY using these inks, photos will appear washed out, yellow etc
Oct 30, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
439 people viewed this question
old marine
old marine
