Question about Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD-60737 stuck on welcome screen
Stuck on welcome screen and green light flashing
  • 4234 Answers
SOURCE: no sound on my mitsubishi wd 60737 fresh out of
Verify that the speakers are enabled. This should be a menu option. If they are enabled and you still get no sound, there is a problem inside the set. You indicate that this is a new set. Return it for a warranty exchange. DO NOT open up the set as that will void the warranty.
Dan
Posted on Dec 01, 2009
lovejoy91
  • 691 Answers
SOURCE: listening to tv audio sound
Try to do a hard reset first
Posted on Dec 14, 2010
  • 8457 Answers
SOURCE: My mitsubishi Model # WD-60737.
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Posted on Jan 11, 2011
i had the same problem and i called mitsubishi they said it is a software malfunction and they are sending me an update to install via flash drive. i am now awaiting the email
bugoy31
  • 1238 Answers
SOURCE: my mitsubishi wd-60737
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 19, 2012
Error code 12 for: Mitsubishi WD-73737 DLP TV Just replaced bulb – tv turns on but is stuck on Welcome screen with flashing green light. I did the :10 reset but no luck Any answers?!
Check YouTube for video about error codes and adjusting screen parameters. There is a certain sequence and button combination to put you into diagnostics mode. Hope this helps you.
Jul 11, 2016 | Mitsubishi Televison & Video
2010 60 inch flat screen stuck on welcome screen has flashing green power button
Check that you have other operating channels. This may indicate that your tuner board is not working, and that you cannot process channel signals for your TV. Likely you have adequate power if the LED is green.
Feb 09, 2015 | Televison & Video
Green flashing light
the green flashing light does not make sense if set is working.
As far as a dark picture if lamp not replaced or replaced with a generic it may be nearing the end of its life, many will dim just before failing.
Dec 05, 2012 | Mitsubishi WD-60737 60 in. HDTV
I can't reset printer. The green light is flashing and screen is saying busy
Sounds like info is "stuck" in the buffer. To clear it out, turn the printer off, wait three minutes and turn it back on.
Nov 13, 2012 | HP OfficeJet J4580 All-In-One InkJet...
My Mitsubishi TV is flashing a green light and gos to the blue welcome screen,does anyone kno what wrong with my tv?????????
I have an old Mitsubishi Tv , your instruction manual is good and thorough and if you don't find it there check online with http://www.mitsubishi-tv.com/ use the support section there.
Jul 14, 2012 | Mitsubishi WD-73C9 73" DLP TV
My mitsubishi wd-60737
Good day!!!!
Jun 19, 2012 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD-60737 60 in. HDTV Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
