Question about Insignia Televison & Video
My Magnavox E175216 SDTV tuner has no way to power on without the remote. Does anyone have any suggesations?
No remote. Can't power on.
2 Suggested Answers
raycalo
  • 358 Answers
SOURCE: Need owners manual for Magnavox SDTV tuner SDTV
bluebonnet_1
I have provided a link where you can look for a manual or ask where to obtain a manual from a Magnavox tech. I hope this helps.
http://tv.manualsonline.com/manuals/mfg/magnavox/magnavox_crt_television_product_list.html
Ray Calo
DISH Network
Posted on Mar 03, 2011
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
On tv 2 the remote controls the volume and power but will not change channels or do anything else. went to system info in tv 1, pressed sat and power. This did not help. Batteries are new.
Hey, Jane!
I can definitely help you with this. Go to the System Info screen like before, but on the TV2 remote press the 'Record button and see if the number in 'Secondary Remote Address' changes. If it doesn't, let me know here, and I will assist you in programming it!
Tommy Faust
DISH Social Media Representative
Nov 07, 2012 | DISH Network IR Remote Control
Remote controls will not work after smart meter installed by Central Maine Power
Power meter install is same as having a momentary power outage as meter is pulled from socket (like pulling extension cord out of outlet) and then new meter is 'stabbed' or pushed back into place.
http://waterheatertimer.org/images/Meter-and-box-500.jpg
I'm not sure if remote can flip off and need to be reset without knowing exactly what the remote operates, and the brand and model number of remote so I can look up possible instruction manual.
If you have a manual, then read about 'reset.'
Please add a comment with specific details for best answer.
Sep 17, 2012 | Hunter 52" Ceiling Fan With Light And...
Remote wont turn tv on
If your remote serves multiple units, make sure it's in the right mode for your TV. (not dvr, dvd player, tuner, other source...). If the TV will not turn on manually (with the power switch on the TV), then make sure it's plugged in and there is power at the plug (try a different power source). If your remote has been out of battery power, sometimes it needs to be reset / reloaded with the correct code for your TV. Check your remote and / or your TV manual for the procedure.
Apr 09, 2012 | Car Audio & Video
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Apr 02, 2012 | 1991 Ford F250
The power went out and my RCA tv needs to have the time set to continue watching. But the remote does not work, and I can't access the menu from the tv
Hello
If the remote control doesn't work, just buy one RCA RCR model universal remote control. Without remote control, you can't set the time to this set.
Mar 04, 2012 | RCA Televison & Video
I have a Bose Wave remote. Battery was replaced with the CR2032 and placed on plastic bracket and slide back into remote control. There appears to be no signal/power to Bose Wave unit. The battery is...
Remotes only allow you to avoid walking across the room to touch the unit for certain functions - like POWER. They don't actually enable or disable its ability to turn on if power is available. Walk over and touch the power control. If it turns on the remote is still malfunctioning.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Aug 04, 2011 | Bose Wave Radio
Televison & Video Logo
198 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
