Question about Blaupunkt Car Audio & Video
Blaupunkt berlin (70's era) car radio parts
I need the mounting piece that holds the berlin head unit to the underdash. the head unit is one of those that looks like a microphone flex pipe with the radio in a rectangle box and push buttons on top. also the speaker plugs for the amp unit. thanks.. I don't know the model because the unit is so old that the number are faded unfortunatley.. can send picture if that helps.. frhrwa@hotmail.com
james klgr
  • 362 Answers
SOURCE: Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Posted on Dec 12, 2007
SOURCE: Part Number for Amplifier IC301
I believe the part number is actuall LA47515
Posted on Jun 01, 2008
  • 111 Answers
SOURCE: car cassette radio: Clarion 4RX5370R - buttons not working.
Go to pacparts.com
Posted on Jul 28, 2008
SOURCE: vw beta car radio, made by blaupunkt
To switch the system on, push the button left. When blue background light appears with the word "Safe" en ter your code. Example: code is 3527 push button nr1 3x, button2 5x, button3 2x and button4 7x. Confirm by pushing button 8 or 9. When the correct code is entered the system will go in operational mode. If the incorrect code is entered "Safe" will appear again. Good luck.
Posted on Sep 10, 2008
eradiostore
  • 1654 Answers
SOURCE: Ritron RTX-x50, 2 prong adapter to single Motorola connector
Contact Ritron at 800-872-1872, ask for the engineering department.
Posted on Sep 18, 2008
How do I enter the code I'm my blaupunkt car radio
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Apr 04, 2013 | Car Audio & Video
Bloom Stand VS91350-01 has piece or pieces missing that holds TV to stand, where can I purchase these parts
Universal "Jimmy stand" for just about any TV available at Walmart or other places. They're 70 to 90 USD though. They include wall mount or a base to set the TV on a table or other surface. Search
sj-Stand-3755BB If you have parts missing on the manufacturer's one, good luck finding those, they typically come as a unit.
Apr 01, 2013 | Panasonic Televison & Video
Have just purchased a cde-100 for an mx3. Does the "mounting sleeve" come with the unit? If so, is it attached to the unit as shipped? I am studying the installation instructions. Are there more explicit...
mounting sleeve is on the radio when you buy it in most of my experiences.
reinforcing the HEAD UNIT-(the cd player itself) with metal straps means that the DIN(the hole the radio goes into in your dash, either single or double) dash piece is probably made of a softer material, and you should mount a small metal strap, usually does not come with the unit, to the units mounting sleeve, and then mount it to the inside of the dashboard of the car with some screws or bolts. this will keep the cd player from moving around, bouncing, etc while you drive over bumps and such.
you could probably get some metal mounting straps either from the box the radio comes in (very few come with them) or get a dash install kit from an auto parts store or a walmart for your car that will probably include all of the things you need including the dash piece, any mounting hardware, and metal straps the factory recommends or deems necessary, and even a wiring harness adapter.
Aug 19, 2010 | Alpine Car Audio & Video
What is the part called? like besel??? the piece that holds the ac buttons and such in a center console
the a/c controls are mounted in the "a/c control head". the "bezel" would be the plastic piece around the control head and radio.
Jan 02, 2010 | 1999 Buick Century
Nikon 70-200mm Tripod Mounting Question
There should be a mount that attaches around the barrel of the lens with a flat part that would allow you to screw that to your quick release plate. The flat part usually have several screw holes so you can mount the quick release plate for or aft for better balance. These mounts are removable so it may have been taken off.
Nov 22, 2009 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
Car radio blows fuses
Hello grm4,
The problem you are having is that the power amplifier or one of the driver transistors has shorted to ground and is causing excessive current flow which is blowing the fuse. That being said what is your location and area. Have you tried looking in a phone book or on the internet for a place that is near you. You would be very hard pressed to find a center that repairs Blaupunkt radios exclusively. But if you look in your area you should find a place that can repair this unit.
I hope this helps
Thank you,
Shuttle83
www.electron-age-technologies-llc.com
Nov 27, 2008 | Car Audio & Video
Blaupunkt IDC-A09 NOT RECOGNISED?
try unplugging both the changer and the head unit, leave it for 10 to 15 mins then plug the head unit in 1st, then the changer.
let me know how you get on
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
How to remove a blaupunkt santa cruz mp36
I'm afraid its a little bit late for corsamad11 but I've just spent hours finding that too much messing about taking a Blaupunkt Santa Crux MP36 in and out of your dashboard will almost render this great quality radio almost useless. Not being securely fixed in the dasboard.
The radio is held inside the mounting bracket by a metal strip each side which are supposed to spring closed to secure the unit. When the two keys are inserted each side of the radio they are supposed to push out these metal strips and at the same time hook onto each side of the radio behind two little lugs. This may work a few times but thats about all. The metal strips don't spring closed and the removing keys don't hook on the unit to pull it out.
Fiddle about with the keys inserted in each slot and at the same time try to push the unit further inside the dash. When this is achieved the mounting bracket lugs can be straightened out and the bracket can be removed with a narrow screwdriver as installed.
Just a very poor and flimsy design on a much loved radio.
May 31, 2008 | Blaupunkt Santa Cruz MP36 CD Player
Blaupunkt 5 cd unit
Hi, was the cd always in the car or have you added it ?
this unit is married to the radio. and will do what your saying. you will need to devorce it from the head unit you have and remarry it.
i have the instructions someware. will did them out please email me mark@blueice-electronics.co.uk and i will send them in pdf format
Mark
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
124 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
