Question about Uniden Cordless Phone
We are setting up new uniden model d1688-5c what is standby
How do I get the ringer back on?
You may download a copy of the manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1680om.pdf
If the phone is in silent mode, see "Silent Mode" beginning on page 10. If the handset volume is turned down, press up-arrow while in standby mode. If the base volume is turned down, press "+" while in standby mode.
Jun 13, 2014 | Uniden DECT 6.0 Cordless Phone ID
How to turned off silent mode
With the phone in standby, try pressing and holding the # key on the handset for 5+ seconds. This toggles the silent mode for the D1660 between "always on" and off. If this doesn't help, check the Ringer volume. (This can be set by pressing the volume + button with the phone in standby on some models.)
If this doesn't work, please add a comment with the specific model Uniden DECT 6.0 phone that you have? There are several. Manuals for many Uniden DECT phones are available from their customer support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are in alphabetical and numerical order.
I hope this helps.
Nov 22, 2011 | Uniden DECT 6.0 Cordless Telephone...
Where do i find standby and how do i shut off answering system
Standby is simply when the phone is not doing anything. It's not on a call, it's not dialing out, and it's not ringing with an incoming call.
As for shutting off the answering system, what model Uniden answering system?
Jul 23, 2011 | Uniden Cordless Phone
I do not have a manual for directions on recording a personal message
For most of the Uniden DECT phones, you set up the outgoing message from the handset. Make sure the answering system is on. For the DECT1480, press Messages/Mute on the handset when the handset is in standby to enter the answering system menu. Then press 5 (or wait until the current message ends). Then press 8 (record new message). Wait for the prompt and then speak your message. When finished, press 8 again. Then listen to the play-back of your message. Press End to save and exit the menu. Alternatively you can scroll through the list of commands and press Menu/Select to enter the sub menu or command.
There are several models of Uniden DECT 6.0 phones. If you have a different phone, you should check your manual. The entire list of Uniden phone manuals is available here: http://www.uniden.com/scat/cordlessphones_mnl . Scroll down to your product and click on the version in your language.
I hope this helps.
(most of the Uniden phones that I know have the same set of directions for the answering system outgoing message.)
Jul 07, 2011 | Uniden DECT 6.0 Cordless Phone ID
I just have a question. We have a Uniden 5.8GHz cordless phone. Is there any way to turn the ringer off completely. My elderly mother is living with us and when I'm not home, I would like to be able to...
My phone is a Uniden TCX905 model.
Ringer Volume
Choose from three ringer volume settings (off,
low, and high). With the phone in standby(normal display), use button on center of handset. Press up arrow or down arrow to adjust the ringer volume.
Jan 26, 2010 | Uniden Cordless Phone
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Accidently pressed spanish on new uniden cordless phone's language selection on main set. How can I change it to English?
when the phone is in standby, press and hold cid/menu.press down arrow to move to language,press select to choose english,etc.when display shows language you want, use up/down arrows to move to another menu item,or press end to return to standby.
Nov 30, 2008 | Uniden Cordless Phone
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
