Question about Zanussi IZ12 Front Load Washer
Drain pump for washing machine
Please could you give me a rough price that I would pay for fitting a washing machine drain pump. Washing machine is only 2 years old. Would it be worth repairing or purchasinng a new one.
    President:
  • 1,462 Answers
The pumps vary a lot but if in the uk, pump cost is about £25 and fitting about £40 but why do you need a pump?
Posted on Nov 12, 2008
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Washer wont drain
    It is iether a bad drain pump, or a broken plastic pump impeller. It may not be a servicable part, depending on your washing machine model.
    Unfortunately, in my experience, it is seldom worth the price many parts stores would charge, if the machine is not still under warranty. In two instances, I've had machines worth less than $200 end up needing the drain pump assembly and the part would be priced well over $100.
    Oct 14, 2013 | Washing Machines
    One time machine will drain next time won't
    It is a common fault that the drain fails to work inmost machines in a period of time and is the most problematic fault in awashing machine.This can be a possible failure within the controller unit as it fails to give output to the drain pump. In all occasions it is important that your observation is mostimportant and so is vital to the identification /rectification and solution. Ifyou have noticed that water has leaked then as the drain hose pump/valve andfittings are located on the underside of the machine it is important that youlook for possible leaks here. In some cases the drain hose would be clogged atthe drain end to outlet of the house and so there will be back flushingresulting in overflow to the outside. Also the drain pump/valve can be clogged.Now remove the drain hose clamps and remove the drain pump/valve, clean thedrain pump/valve, use back flushing to clear off all dirt. Now test using powerto see if this works and can be simulated. When refitting, the hose must be tightenedproperly. If the pump/valve does not work even with power then it must bereplaced. If there is intermittent powerto the drain valve/pump then the program controller unit is a suspect.Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use aspirit level- so that all water will drain to the outlet port and thereby thereis no residual water remaining. Replacing the pump on a Bosch machine, please checkthis link for tips:http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
    Aug 03, 2012 | Maytag Neptune MAH5500B Front Load Washer
    Fit a new drain pump
    It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
    Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
    Replacing the pump on a Bosch machine, please check this link for tips:
    Jul 02, 2012 | Zanussi Washing Machines
    Kenmore 98702 not draining
    sounds like the pump failed, its always worth getting repair price first as could be as little as 40 or 50 pounds to supply and fit a pump where new machine will cost few hundred.
    May 05, 2012 | Kenmore 98702 Stacked Washer/Dryer
    Washer fills with water but does not spin or drain.
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Apr 03, 2011 | Washing Machines
    Hi, I have a F&P Intuitive washing machine about nine years old. The machine is getting no power, it just stopped half way through a cycle. I have checked the wall power socket and it has power but the...
    what country are you in?i know the prices for Australia. the only parts you might need are 1- control module 2- diverter or 3-drain pump. please reply and i can give you an estimate of what the prices could be.
    May 22, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
    The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
    All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
    You need to clean your washer with bleach in the front seal by hand some times.
    Its the price you pay for saving water.
    Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
    SUD and F02
    This error combination is commonly caused by a clog in the drain pump. The following link explains how to correct:
    http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
    If you have questions, please let me know. If the error codes do not clear after checking the drain pump, you may have a pump that has been damaged. If this is the case, it will have to be replaced. This additional link explains how to replace one:
    http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
    If you require a new pump, replacements can be purchased at searspartsdirect.com, appliancepartpros.com, repairclinic.com, or pcappliancerepair.com. All of these sites offere competitive pricing, so shop all of them for the best price. Use your model number as your search criteria. I hope you find this information helpful.
    Apr 05, 2009 | Whirlpool GHW9200L Front Load Washer
    Zanussi IZ12 Front Load Washer Logo
    79 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
