Question about LG Washing Machines
I have a LG WD-80154TP washing machine and it will not operate and gives a message on the LED screen stating 'eE' flashing...What does this mean
2 Suggested Answers
  • 1746 Answers
SOURCE: i have a LG WD-80154TP
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799 This should give you an answer to your problem. Good luck.
Posted on Jun 13, 2011
I have an lg washing machine model wm2301hr. About 15 minutes into the wash cycle I got an error message EE. Since I couldn't resolve the error I pushed drain/spin and water leaked onto the floor.
First if the error code is "EE" then unplugging unit from power<waiting a few minutes and then plugging it back in might reset control board.
Second, are you sure it is "EE" and not "tE" or "fE"?
good luck
Mar 15, 2018 | LG Washing Machines
I have problem in my lg wd-80154tp i press play butten it off
This can be due to errors on the board or it can be related to fault in the inlet valve or control panel.
Check and see if there is moisture within the board or the panel that can cause errors , if so use a dryer to warm off.
If not the board is a suspect.
Feb 07, 2013 | Washing Machines
LG WD-80154TP washing machine is showing OE, which means the plug or filter is clogged. I cleaned both and am still getting the same message. What do I do now?
have you done a reset turn off machine by the mains leave off for 10 min's make sure door is open at all times make sure machine on/off button is off and the programmer is set to the off if you havent got a off on the programmar put it on a spin program ok then switch the mains back on turn on the machine on off button then press start then shut the door that is a reset if you still have problems get back to me ok
Nov 07, 2012 | Washing Machines
LG WD 80260 NP washing service manual / circuit diagram
tE is heating error. Water not heating, Could be a faulty element, faulty wiring, faulty temperature sensor or faulty control board.
Jul 07, 2012 | LG Washing Machines
Why washing machine cannot operate?
Whats the make and model no. as the LED's flashing is probably a fault indication. Dependent on the amount of times it flashes or what sequence the LED's are lit will give you an idea of what to look for. Have a look in your user manual as sometimes the will tell you what they are and how to solve it if its something simple like checking the filter.
Hope this has helped Colin.
Feb 04, 2012 | Washing Machines
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
95 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
