Question about LaCie Computers & Internet
Catalog file entry not found for extent
Verifying volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Error: This disk needs to be repaired. Click Repair Disk. Verify and Repair volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Volume repair complete.Updating boot support partitions for the volume as required.Error: Disk Utility can’t repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files. Verify and Repair volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Volume repair complete.Updating boot support partitions for the volume as required.Error: Disk Utility can’t repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files. Verifying volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Error: This disk needs to be repaired. Click Repair Disk. Verify and Repair volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Volume repair complete.Updating boot support partitions for the volume as required.Error: Disk Utility can’t repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files. Verifying volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Error: This disk needs to be repaired. Click Repair Disk. Verify and Repair volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Volume repair complete.Updating boot support partitions for the volume as required.Error: Disk Utility can’t repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files. Verifying volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Error: This disk needs to be repaired. Click Repair Disk. Verifying volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Error: This disk needs to be repaired. Click Repair Disk. Verify and Repair volume “disk1s6” Checking non-journaled HFS Plus Volume. Catalog file entry not found for extent The volume could not be verified completely. Volume repair complete.Updating boot support partitions for the volume as required.Error: Disk Utility can’t repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files.
3 Suggested Answers
  • 16 Answers
SOURCE: My mac is not recognizing my disk from my hard drive
Open Disk Utility (as I'm sure you already have) and select the main partition of the problematic disk on the left side, which should be titled disk1s10. In the First Aid tab, click the "Repair Disk" button on the bottom right hand corner of the window. *Note: If this is the current boot disk, you will have to boot off of the Mac OSX Install Disk by inserting it and holding the "C" key while it is turning on. Select your language and choose Utilities --> Disk Utility from the menu on the top of the screen, then following the above instructions.
Posted on May 03, 2010
sayedmohu
  • 633 Answers
SOURCE: Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
Posted on Jun 07, 2010
I've tried the chkdsk command, it suddenly get to 69% complete and remains there for 7hours.
In Windows 7 use Ctrl+Shift+Esc rather than Ctrl+Alt+Del. It gets you to Task Manager quicker. Select Task Manager, the Performance tab, Resource Monitor, and Memory tab. What are the figures for Hardware Reserved, In Use, Modified, Standby and Free?
Please download and run the Windows 7 Upgrade Advisor and upload a copy of the report to your Sky Drive as a shared file:
https://www.microsoft.com/en-gb/download/details.aspx?id=20
Jan 23, 2014 | Seagate Computers & Internet
Bad sectors
Yes your hard drives electronics are failing. you need to replace your hard drive.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
When trying to back up files on Mac G4, I encountered a disk reading error. went to initalize, then to verify. error says Verify and Repair disk “disk2s1” ** /dev/disk2s1 Invalid BS_jmpBoot in boot block:...
You don't say what Mac OS version you're running or many other details, but try running Disk Utility or Disk First Aid, normally in the Utilities folder, and see if it can repair anything.
It sounds like the drive is failing or has already failed.
PS: That Mac G4 is well past its prime. :-(
Oct 11, 2017 | Western Digital My Book Essential 1TB...
Jun 07, 2010 | LaCie (301015) 120 GB Hard Drive
May 03, 2010 | EZQuest Cobra Plus (B12660) 120 GB Hard...
Grey screen
It sounds like a corrution of the "map" it uses for the system, diskwarrior should sort it out but maybe getting the seller to sort it would be fairer, it could also be the hard drive failing
Oct 23, 2009 | Computers & Internet
All data has "disappeared" from my 300G usb 2.0 drive.
you can use a software called g parted , you have to make a dos bootable , and then mount volumes to make the drive ready.
gparted will help you... try the trial version .if you dont susceed let me know.
Feb 06, 2009 | Iomega Silver USB 2.0 Hard Drive
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
My Lacie wont mount its a rugged 250 gig, Was working fine till it got un plugged before being ejected. now will not mount. I can see it in disk Utilities. try to repair but can't the report is :The...
Mount.... sound like you got a Mac... Don't use the Mac sugested fix. The lacie Website has many revovery software options and Third party software is very good at that as well
I would try that first or try to contact a lacie tech and/or a mac tech.
If this is helpful please email and notify fixya. Thanks
Mar 15, 2008 | Computers & Internet
Help with big extreme disk partition access.
Don't know what operating system your using but in Windows 7 and up it's easy to partition any drive even while windows is running.
Go to --> Control Panel\Administrative Tools\Computer Management\Disk Management and right click - set the size.
You can change it any time as long as whats in it isn't bigger than the size you want to make it. I have a 1 TB in this computer and that's how I did it after discovering that my old drive tools didn't work on this.
For any info on this procedure (or darn near anything you can think off) you can always go to youtube for step by step instructions.
Just watch a few first because some people are better teachers than others.
Mar 13, 2017 | LaCie Bigger Disk Extreme 2000 GB Hard...
Computers & Internet Logo
381 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
