Question about Alpine MRP-M500 Car Audio Amplifier
How to change an alpine mrp-m500 fuse
Can't get the fuses out wtithout seaming like im going to break it. does it come out easliy?? or is there something to it??
I have 8 gauge power wire with 60a fuse (reccomended) but when i turn the power on, the light on the amp turns on, and then fades while blinking, which means it goes into safe mode. Could the 60a fuse...
Hi, the safe mode indicates the speaker impedance is too low. It doesn't reflect the power to the amp. Check the resistance of the speaker and wires with an ohmmeter and verify it is 2 ohms or greater. Can you tell me what speaker you have?
May 08, 2011 | Alpine MRP-M500 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
I have an Alpine MrP-M500 that is not giving off sound. The light is diming, and blinking meaning it is in "safemode." ive done everything, new fuses, ground is good, wires are good, sub is good. I got it...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Alpine MRP-M500 Car Audio Amplifier
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
I hook up my alpine amplifire and the red light for the fuse protection comes. on what could it be?
It is either hooked up wrong or the wire you are using is too thin. Be sure to use the proper gage wire for the output of the amp.
Mar 26, 2009 | Alpine MRP-M500 Car Audio Amplifier
Alpine MRP-M500
You need to check the Fuse on the Power Wire and check the ground wire to see if has loosened up. Also check Power Wire as well.
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Jan 10, 2009 | Alpine MRP-M500 Car Audio Amplifier
Alpine MRP-M500 Car Audio Amplifier Logo
98 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
