Question about Moen & Replacement Cartridge
How to remove a moen 1248 cartridge - Moen & Replacement Cartridge
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: removal of moen #1248 cartridge
If your faucet is Moen Hi flow roman tub, attach is the removal and installation for 1248 cartridge you need a special tool look at link below.
Attached images pdf.gif MT335H.pdf
Posted on Mar 27, 2010
That was exactly the solution I needed for my Jacuzi bath tub with the two handle faucet. The use of the screw in the top of the cartridge was needed to be able to get a strong enough hold on the cartridge stem. Mine is all recessed about 2 1/2 inches so I grabbed the screw head and stem with long nose pliers, and then clamped down on the pliers with a set of adjustable pliers, and then used a 1/2 block of wood as a lever to get pressure on. That got the cartridge to pop out! Thanks!
Posted on Sep 30, 2011
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How is the cartridge removed on the faucet?
    How To Repair Cartridge Sink Faucets at The Home Depot
    www.homedepot.com/.../project_guide_repairing_cartri...
    The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
    Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
    Dec 03, 2015 | Plumbing
    Monticello 1248 cartridge removal
    There is an actual tool for the Moen cartridges, not sure on the price but if you contact Moen they can help. As for actual removal , once the handle is removed there is a horseshoe shaped pin that secures the cartridge in place that needs to be removed. If the cartridge has never been removed you will need a bit of elbow grease to pull it out as they tend to stick very well.
    Oct 19, 2014 | Plumbing
    Remove stem of moen shower cartridge,
    Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen:
    http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
    Or your local home center or hardware store should have one in stock if they carry Moen parts.
    Jan 08, 2012 | Moen Plumbing
    I am not sure how to get cartridge 1248 out of my moen 6990 roman tube valve
    Pull straight up with all you got!!!
    They are a bugger to get out!!!
    Your local plumber maay have a puller to help with the job...
    heatman101
    Aug 08, 2010 | Moen & Replacement Cartridge
    Removal of moen #1248 cartridge
    Mar 27, 2010 | Moen & Replacement Cartridge
    Moen Castleby T6988 Roman Tub Faucet
    with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
    Feb 12, 2009 | Moen Castleby Two-Handle Widespread Roman...
    After consulting with Moen re: 2 knob Tub "cartridge" replacement, 12 yrs old, cold water not running, I did what I was told, after receiving the replacement cartridge 1248. (warranty replacement) The...
    If the water is off but still coming through, open a tap or two on one of the lower levels.
    Basically the old stem does come out thru the top of the valve. Hopefully Moen sent you the tool to do this job. The tool is a 3/4"diameter about 4 inches long. Even on one end and two little tabs on the other.
    Take the handle off stem. Remove the upper retaining nut, usually chrome. Pull out the two plastic upper stem pieces. Insert the 2 tabbed end into the stem area. You will feel the tab drop into the retainer ring. Slowly rotate the retainer ring out Counterclockwise. After the retainer ring is out then put the long screw in the stem and pull it out. Sometimes a little leverage helps here.
    You will have TWO retainer nuts. The first one is easy just under the handle, the second will require the special insert tool.
    Please rate this response and good luck, Phil
    Dec 29, 2008 | Moen & Replacement Cartridge
    Moen & Replacement Cartridge  Logo
    124 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
