Question about Concord Camera Eye-Q 4360z Digital Camera
IF I TAKE A PICTURE OUTSIDE IN DAY LIGHT IT IS OVEREXPOSED
I HAVER TRIED TO FIX IT BY RESETTING THE CAMERA BUT IT IS NO BETTER IT WILL ONLY TAKE PICTURES AT NIGHT WHEN THE FLASH IS NEEDED
  • Anonymous Mar 27, 2008
    In daylight, the pictures are overexposed (white). Indoors in low light the pictures are ok. The camera ( Minolta G530) is three years old. I have tried every manual adjustment on the camera to correct the problem. Nothing works. I suspect that the lens is shooting wide open in every setting.
  • Anonymous Apr 04, 2008
    Genius:
  • 2,985 Answers
Say more about the poor outside images - whats wrong with them?
Posted on Aug 21, 2007
Presumed overexposed Canon IXUS 220 HS
Check the information on exposure in the manual
Apr 15, 2017 | Canon Cameras
Outside picture are white
Make sure the ISO is set to the lowest number or even to "auto ISO". The best way to avoid these lighting problems is to adjust your aperture settings, your shutter speed and your film speed when shooting. Additional details about thus sibject could find in the Samsung_S500_Owners_Manual in section about Settings & Mode.
Its possible that you are interesnting to check other
information, so visit this two sites Fix-Overexposed and this other take-better-photos-in-5-easy-steps.
Finally, remote but possible, could be t
he symptoms of a stuck or "sticky" shutter, this are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Hope helps.
Apr 29, 2011 | Samsung Digimax S500 Digital Camera
I always put the flash on Auto but every picture requiring the flash comes out overexposed, even though the flash is required for the shot. Any ideas?
yes ...change the environmental mode...and set it to normal..cause it may be on night vision or something like that ..or ..choose it by the need of the moment ..day light ...inside..outside..etc
May 30, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
We have a canon powershot A410 digital camera with 3.2 mega pixels (purchased brand new in fall 2007) and recently, whenever we take pictures outside, they come out completely white (overexposed). The...
Hi there its a chance of sersor damaged. He not able to read the light. Thats why outside image are over exposed. I suggest you visit service center for check or repair the lens sensor.Thanks.
Apr 07, 2010 | Canon PowerShot A410 Digital Camera
Olympus mju850 - fine at night but hugely overexposed in daylight
it is ur luck if camera still works in indoor pics then only take indoor pics but the pics are not crisp and clear they need to be there will be dis colored and scratchy but u can try see which are better i think pics without flash with adequate light will be better one's
i am here to help u in this if u like
Apr 08, 2009 | Olympus mju 740 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Over exposure
Hey - have the same problem. All my still pictures are coming out overexposed, no matter what setting I use. Tried resetting, tried new battery, tried new memory card, tried different exposure settings. Nothing fixed it or affected it. However, my movie exposure works great so I can take movies just fine. Are you able to take movies with no overexposure?
Jul 25, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Digital camera woes
Hey libra2,
I would try resetting the camera to its default factory settings. Directions on how to do this are on page 20 of your camera manual, and I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 13, 2008 | Olympus FE-210 Digital Camera
Concord Camera Eye-Q 4360z Digital Camera Logo
Top Concord Cameras Experts
Michael Galve
Michael Galve
Are you a Concord Camera Expert? Answer questions, earn points and help others
