Question about InFocus IN72 Multimedia Projector
IN72 Projector problem
About a year and a half ago, we purchased an IN72 projector. It has worked wonderfully up until this week.
In order to optimize the performance, we are using a 40 ft. HDMI cable from our digital cable box to the IN72 projector. The problem we are experiencing is this: when you turn on the system (cable box and projector), it shows a picture for approximately 3 seconds and turns black. We tried with component cables and the component cables work fine. Also, we tried hooking up the projector and PS3 with the HDMI, and it did not work with the projector, but when we hooked the PS3 to another TV using the 40 ft. HDMI cable, it worked fine. This leads me to believe that the problem lies in the projector.
Thank you!
Kaylan
I had the exact same symptom with my In72 when the bulb needed replacement. My brother's bulb exploded in the machine but when mine went out, it did exactly what you're experiencing. I'd rather have the quiet way myself... anyways, I would suggest a new bulb. You need to search around the internet. I think I found mine for $360 somewhere.
Posted on Dec 27, 2008
My understanding when we purchased our IN72 2 years ago is that there wasn't any additional benefit for Cable box using HDMI since the IN72 does not transmit audio so using component cables for cable was optimized enough. We have our DVD player connected via the HDMI only. Possibly the transmission from cable box through an HDMI is not compatible audio is confusing it? hard to say. Cable HD channels look awesome thru the compenent cables, the max for IN72 is 480i anyway.
We've got 35 ft cables for all 3 hdmi, compenent, and that vcr one too and it's worked great.
Posted on Nov 22, 2008
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
The image via HDMI does not work in projector Infocus IN72
what is the image from? make sure you have the right in put and that the resolution matches. try swapping cables, too.
Feb 08, 2010 | InFocus IN72 Multimedia Projector
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Can I reset my lamp timer without replacing the lamp?
That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
Mar 25, 2009 | InFocus IN72 Multimedia Projector
Problem with the InFocus IN1 Gaming Projector (when recieved) - No red, constant yellow tinge and constant lines.
It is because the xbox 360 is set to 60hz, change it to 50hz and it will be clear like it's meant to be. However, some 360 games are 60hz so for those games the quality is not good.
Aug 10, 2008 | InFocus IN72 Multimedia Projector
Infucos IN72 projector
Hi Ronnel
This is a common Mainboard failure on a Projector.
The unfortunate thing is that the Mainboard will either have to be repaired or replaced.
Apr 18, 2008 | InFocus IN72 Multimedia Projector
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
Dark Picture
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Nov 13, 2006 | NEC VT460 Multimedia Projector
InFocus IN72 Multimedia Projector Logo
519 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
