Question about Saws
Inital change blade on skilsaw 5500
Can not get bolt to stop turning for initial blade placement
efs_perpends
  • 1996 Answers
SOURCE: cant get blade off
I don't know which model you're using, but normally there's an arbor lock button on the motor side of the blade somewhere that allows you to lock that whole middle housing down so it won't turn. Look underneath the motor and see if you can't find some kind of lock botton or lever. That will make it easy to loosen the nut and tighten the blade down correctly.
Otherwise you're going to have to improvise some way to lock it in place enough to break that nut loose.
Reply with a model # and I can try to find a parts schematic to check for you...
Posted on Apr 10, 2009
SOURCE: How do I change the blade?
use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
Posted on May 08, 2009
  • 15 Answers
SOURCE: Where is the blade lock button on a skilsaw 5150 2
I have that saw just stick a screwdriver into one of the teeth perpendicular to the blade and when you tighten the bolt it will keep the blade from turning works like a charm .
Posted on Jul 07, 2009
  • 5603 Answers
SOURCE: How to I change the blade on a skilsaw cicular saw?
The blade is USUALLY held by a LEFT HAND thread bolt. Sometimes they have a diamond insert in the blade that must be removed if the saw has a matching boss on the arbor. If the saw has that, you punch the insert from the blade and engage the diamond over the boss on the saw then put the clamp washer on top and then install the bolt.
OFTEN there is a button near the blade are to push in to "freeze" the arbor so the bolt can be removed/installed. These are USUALLY left hand threaded bolts.
Posted on Sep 14, 2009
  • 15 Answers
SOURCE: How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Posted on Jun 08, 2010
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
How to remove arbor bolt to change blade
Best thing to do is to just rest the blade teeth against a peice of scrap wood, and use the allen key/spanner to undo the bolt. As the bolt undoes in the direction of the cut, the blade teeth should dig in and stop it turning. If the blade lock isn't working anymore, it could mean that it has broken inside, so be careful, incase there is a bit of loose metal in the gearbox, it will be quite catastrophic if it gets caught in the gears.
Jul 18, 2014 | Bosch 7 - 1/4" Skilsaw Circular Saw
My Skil Worm Drive Skilsaw Blade stops when cutting
If the blade stops it could be from a loose hex bolt, flanges missing or you have a gear problem. UNPLUG tool and check the blade first. I would remove the fill screw on the gearcase and see if the oil has metal shavings in it, if it does the gears are worn allowing the blade to slip. If not I would recheck the blade. Did this suddenly happen and if so what did you do prior to your problem
Mar 12, 2012 | Saws
How do you tighten the blade bolt on skilsaw model 5150? Thw shaft just turns and won't tighten.
There is a button on side that lock blade . Push on button turn blade by hand till you feel button engage now you can tighten bolt left hand threads
Jan 26, 2011 | Garden
Blade change skilsaw 5150
The locking button on this saw is designed for safety. If you are attempting to change the blade it should NOT be plugged in. It sounds as if someone has pushed the lock button while the motor was running and sheared it off.
The only tool that is required to change the blade is the supplied wrench or an equivalent box end. If you cannot make the repair yourself for have the equipment repaired you can take a pair of vise grips. (Use cardboard to prevent warping or gouging the blade) and clamp the edge of the blade below the teeth. The vise grips will stop at the front of the saw as it is too large to pass by the guard allowing you to loosen the nut. Clamp the new blade in the same way only the back of the saw will be used to tighten.
I highly recommend that you either repair yourself or have the tool repaired by a professional.
Parts schematics are all over the net for this tool, here is an example:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/skil/5150
As you can see most of the mechanical parts are only a few dollars and it could save you from serious injury during operation.
Feb 13, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
How do I replace a skilsaw blade?
The saw has a bolt in the center of the blade. The saw blade will have to be held in place, (so it can't turn), while the bolt is being loosened. Pay attention to the rotation direction, as your replacement will need to rotate in the same direction. Once you have removed the bolt, there is a centering spacer that fits between the bolt and the blade, remove it paying attention to how it fits..you will need to put it on the new blade in the same manner. You can now remove your blade and replace. Good Luck. I hope this is very helpful!
Nov 14, 2009 | Craftsman Saws
Sep 14, 2009 | Bosch Saws
at times
May 08, 2009 | Saws
Saws Logo
49 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
