Question about Paradyne 6211 ADSL2+ Router (6211I1200)
Port forwarding I can't get my 6211/12 router to port forward. Everything else works fine. I'm trying to connect a webcam for remote viewing using webcamXP. works ok locally but not via the internet. I've disabled the windows firewall and added port 8080 on the router but still no joy. any help?
    Novelist:
  • 143 Answers
Try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
ciao
Posted on Oct 24, 2008
Port forwarding 3G21WB Problems
This WEB site assists in setting up port forwarding by make and model of your router.
Port Forwarding Guide by Make and modelhttp://portforward.com/
Mar 16, 2012 | Computers & Internet
Port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
Explain how to go about using a static or dynamic link to access a remote computer that has an ethernet PTZ camera from d-link install so that the camera can be viewed remotly.
you need to do some port forwarding and possibly use a static address assigned to your camera.
remotely is this context means being able to access the camera feed when the camera is behind a router. in essence what you are trying to do is this:
camera ------ (private) router (public) ---------- internet ------- remote user.
the private side or your router is the one that you control, the private side is what is known as being "behind the router"
your router requires to be able to forward traffic from the public side for this you need to do some port forwarding.
a practical example that you can follow can be found in this website if you look into the Support Resources>FAQ section under the title "How do I remotely view DCS-6620 or DCS-6620G series cameras that are behind a router or gateway?"
the article from dlink goes like this:
For each camera that resides behind a router or gateway, three ports must be forwarded by the router to obtain both audio and video. If audio is not desired, only the HTTP port will need to be forwarded. The three default ports are as follows:
  • 80 (TCP) HTTP Port (allows access to web-configuration and transmits video if other ports are not forwarded)
  • 5002 (TCP/UDP) Audio Channel Port (transmits synchronized audio)
  • 5003 (TCP/UDP) Video Channel Port (transmits synchronized video)
These port numbers will need to be changed in the camera configuration on each additional camera that is added behind the router. Port numbers can be changed from the Advanced > Network screen.
please look in to the section described within the link to see how camera and router need to be configured.
I hope this helps!
Apr 07, 2010 | Computers & Internet
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
I need to access a remote LAN through the internet. our church office is on verizon DSL with a westell 7500 modem. I have security camera's attached through an Ethernet cable. I need to be able to use...
You need to install a software that will manage your LAN's video recording. That software should work fine within your LAN and is usually provided with the Video Capture Cards where your cameras are connected. This software should have a web portal for you to access via internet utilizing your forwarded port. Thus, you must tell your video software to use your forwarded port for internet viewing. Without this web portal, you can't access your remote LAN videos via internet.
Feb 01, 2010 | Computers & Internet
Trying to port forward requests to the IK-WB21A webcam. From inside the house it works great. From outside, port forwarding port 8001 to 80 and I get NO response. Tried tcpdump and there is no response...
What are you using to view the Camera? Is this the only IP camera you are viewing/.accessing on the network? If it is not, are you using different IPs in the non-DHCP pool.
Typically you do not have to set-up port forwarding to gain access to the camera within the network. Normally port forwarding is set-up when you are outside your network and need to gain access to different applications/devices in your network using the same static IP address.
Let say you have a camera ip on 192.168.1.20.
You can connect to the camera with your web browser inside your network with the IP 192.168.1.20 (obviously), but if you have the camera set up to only be triggered on a specific port (other than the browser's default 80) let's say 100, then you would enter 192.168.1.20:100.
If the only thing on your network is the camera that you want to access from outside. you would setup in your router to route all incoming requests from port 80 (which is the web browser default) to the IP of the camera. Sometimes routers ask for a range just enter 80 to 80.
If the camera is working on a different port like 8001 then you would port forward 8001 to 8001 to IP 192.168.1.20. You would enter in your web browser (off-site) your static IP 69.132.54.176:8001. But I would suggest if the camera is the only thing you will be trying to gain remote access to, then leave it at 80 and set up forwarding for port 80 to the IP.
That way you can set up a free DNS service and not worry about paying extra for a static.
Nov 13, 2009 | Home Security
Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
May 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Setting up port forwarding: belkin wireless g plus mimo router
candice,
you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
Aug 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Parker Vision Router WR1500
You need to forward the remote desktop port to your server. The Remote Desktop port is 3389. Go to the port forwarding section of your router and find out your Server's network IP address and assign it to forward the Remote Desktop port of "3389". Save your changes and try connecting again.
Sep 06, 2007 | ParkerVision SIGNALMAX WR1500...
Paradyne 6211 ADSL2+ Router (6211I1200) Logo
223 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
