Question about Garden
Manual for greenfield evolution ride on mower 13/32
13hp 32" cut 340cc ride on mower - want a manual
  • 81 Answers
SOURCE: Mower wants to stall when blades are engaged
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Posted on Jun 23, 2009
moretons
  • 155 Answers
SOURCE: We mow 2 acres with a Greenfield ride-on.
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Posted on Jul 23, 2009
  • 203 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
vincob
  • 718 Answers
SOURCE: I need a diagrahm of a belt drive greenfield ride
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
  • 3 Answers
SOURCE: i need to find a manual for an AMC EXPLORER 13/33
take your old belts to the shop they will mesure them then write the numers down,they didnt come with a manual only for the motor
Posted on Nov 13, 2010
I need starter motor fo 18 oh greenfield fast cut ride on mower
Who manufactured the engine for this mower ? Engine parts are usually separate from the actual mower, Search the engine model number for a parts break down, also sometimes you might need the serial number due to changes in manufacture,,Hope this helps...
Sep 09, 2017 | Fast Garden
How do I remove a bearing from the shaft?
cut it with an abrasive cut off tool.
Aug 02, 2016 | Garden
GREENFIELD 8, 11 & 12 HP ANNIVSARY manual
Some manufacturers will not sell the full manual to consumers, perhaps yours will.
Your best bet is to email them with the full model and serial number of your mower with your request:
http://www.greenfield.com.au/contact.html
Jun 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
Cutting deck on greenfield evolution mower will not disengage
Usually this is caused by badly worn belt or incorrect type of belt fitted, check allignment, tension, belt size should be marked as A... not 13A..... if marked as the latter it is an "automotive" type belt not suited to "slipping" when belt loosened to disengage cutter. Check also for the belt has not rolled over in the groove.
Oct 31, 2009 | Greenfield Industries Disston #752980 Mm...
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Mark.
Jul 18, 2009 | Garden
Garden Logo
1,657 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
