Question about Sanyo DS24205 24" TV
Sanyo TV model DS25710 or DS25730
TV was purchased in Sept. of 1998. Problem is: picture has become a horizontal line in the middle of the screen that jumps around a little but refuses to become a picture. :) Sound is OK. The line appears when the set is turned on and as I said is not steady in the middle but bounces around. There is no flash of any form when the set is turned off. I hope I'm saying that right. What I mean to convey is that on and off appear to behave normally.
  • Ward Turner Jul 31, 2006
    Thank you very much for the information. Extremely helpful.
BLOWN CRT TUBE
Posted on Nov 22, 2011
    Problem Solver:
Bad vertical IC LA7841, just repaired one
Posted on Jul 02, 2009
My tv (ds25730) had a shorted output transistor replace, pulling in on right hand side of screen liking about 1/2 inch drom having a full screen.
Posted on Oct 04, 2008
    President:
  • 3,130 Answers
Set has a bad vertical sweep IC. Also This Sanyo has a tendancy , when the IC blows out , to take the fusable resistor in the sweeo supply that feeds the vertical IC. This set should only be serviced by a trained technician because of ther high Voltage that lingers within. This repair should run you antwhere from 85.00 to 150 bucks. Good Luck
Posted on Jul 31, 2006
How can I fix a problem with my Sanyo standard CRT TV?
well,the last of the dinosaurs is in its death throws,a new picture tube is 500 bucks,a flat screen is 400,its up to you,do you replace the tube and pay to install it or buy a flat screen and not worry about it for a few years and save electricity
Jun 11, 2015 | Sanyo Televison & Video
Can I fix a horizontal line problem in the middle of the screen?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in "my service table today" as key phrase, in the search box [at the top right] of the display window. You'll get the related posts easily.
Jun 10, 2015 | Sanyo Televison & Video
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
A thin white line horizontally in middle of screen At first could wiggle the cable conection on back of tv and it would go back to full screen now it won't
it sounds like you have horizontal colapse a very complect repair try hitting the tv if the screen comes up full picture then its a dry joint if not there is an ic or power fault toss it
Jun 18, 2010 | Sanyo DS25390 TV
We have perfect sound but only a thin horizontal line in the middle of the screen.
this is a capacitor that has gone bad in the vertical delfection stage of the tv. it is an very easy and cheap fix if you know someone who knows how to solder and replace electronic components. If not then you'll just have to get another tv as taking it into a tv repair shop is not worth the cost. You could get another tv for what they will charge you to repair it,
May 31, 2009 | Sanyo AVM-3659S 36" TV
Black screen with a horizontal white line across the middle.
You would need to replace the flyback on this and your looking aroung $65 parts and $85 labor to shore this problem up. We can recommend you a repair shop or you can purchase a new TV its all up to you
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Sanyo DS24205 24" TV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Sanyo DS24205 24" TV Logo
1,135 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
