Question about Frigidaire Refrigerators
Model ffu1464fw1 stopped frezzing light on no temp
Went down and all food was thawed out
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Lights on, sounds like running, everything thawed
Check your compressor, the relay and the computer board. These are all located at the back of the fridge if all check out ok, then check your thermostat
Posted on Feb 12, 2009
heatman101
  • 43501 Answers
SOURCE: My freezer just stopped being cold and all the
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 18, 2010
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
Sep 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hotpoint ff200e
I would be better for the unit if you unplugged it and allow to completely thaw. Also, double check all food as salad dressings also goes bad in higher than normal temps. I reason behind the unplugging is to allow the unit to thaw and reset. 50/50 change if you close up the unit it will function as normal.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 31, 2014 | Refrigerators
Ice make is not working New water filter as of yesterday, it dispenses water fine for drinking but does not dispense water for ice Model #RS2556RS
This could be a frozen water line that feeds the ice maker. Turn the temperature down on both the freezer and the refridgerator and wait at least 48 hours for the temps to adjust and thaw the line. If you are in a hurry you could turn off the unit and remove all food and then use a hair dryer on the water line to thaw it out. Good luck!
May 25, 2010 | Samsung RS2556 Side by Side Refrigerator
Ice dispensor not working
Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Maytag RSW2400 Frig. I just replaced the Dual Water Valve kit.(12001415 kit) I have water going up the the back of the frig. but not into it.I tried to blow air through it but it seems to be...
Sep 26, 2009 | Refrigerators
My Samsung RS267LBBP side by side has low water preasure at the dispensor after only three weeks after changing the filter. I've changed it three times with the same result. Also, I've noticed the ice...
with samsung refers the control board and ice maker have be updated Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Feb 12, 2009 | Kenmore 53642 / 53644 Side by Side...
GE monogram
I have a Ge Monogram 42" side by side. The temp on both side are not cold enought and I tried to change the temperature setting to colder but it's went right back. All the food started to thawed. PLease help. Thanks
Jun 18, 2008 | Refrigerators
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
