Question about Tripp Lite Lite SmartOnLine SU2200RTXL2U UPS System
Tripp Lite Lite SmartOnLine SU2200RTXL2U UPS System - no power
  • 548 Answers
SOURCE: No Power when turn on so battery wont charge
Try leaving it off, but plugged into the wall outlet so the batteries can charge up. If they are new, they are probably without a charge. The instructions should indicate how long it needs to charge - probably most of the day.
Posted on Jan 05, 2009
jvpacoin
  • 91 Answers
SOURCE: Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Posted on Jun 04, 2009
gripfitter
  • 557 Answers
SOURCE: I had my UPS from Tripplite at least 4 years or
Battery is very easy to remove. Take it out and test it. If you dont have a meter to test it take it to an interstate battery store they will test it for you. They sell new ones should you need to purchace one.
Posted on Dec 13, 2009
SOURCE: unable to open the enclosure, how, no screws visible?
There are 2 (very deep) screw holes at the back of the UPS, but you'll need a long (8"+) philips screwdriver to access them.
Posted on May 13, 2010
  • 3 Answers
SOURCE: Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Posted on Oct 19, 2010
Batteries won't charge Tripp lite
You don't indicate in the description the age of your UPS, but if it is more than 4-5 years then it is likely time for replacement.
Jan 12, 2014 | Tripp Lite SmartOnline SU1500RTXL2Ua UPS...
Tripp.lite ups fault displayed and beeping
My Tripp Lite was showing a fault this morning for no logical reason, ran this self test as suggested and all cleared. Thanks.
Apr 24, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
I need the default password for the SU2200RTXL2U ups?
User Name: apc
Passwork apc
You must have a network card installed to log into the UPS. Also You must use a 940-1524 APC cable. There is no other way then this. Use putting to log in.
May 26, 2011 | Tripp Lite Lite SmartOnLine SU2200RTXL2U...
Tripp lite avr 550 ups keeps on discharging while power is still on
Check the fuse. Check the input voltage. Since it's AVR, it keeps discharging if the input voltage is below the minimum
Aug 05, 2010 | Tripp Lite AVR AVR550U UPS System
After a short power outage (resetting breaker) the protected outlets no longer provide power. Is there a way to fix or do I need a new UPS?
The unit may need to recycle itself. Remove the loads and turn the unit off. Plug it back in, wait a bit, then turn it on. Then try your loads on it again.
Feb 18, 2010 | Tripp Lite Tripp-Lite HT1500UPS Home...
4 battery schematic for a tripp lite su1500rtxl2ua
There are two wires from the charger..one is RED and the other is BLACK...while the unit unplugged from the power source ( wall ) connect the four batteries as demonstrated...
RED Wire to 1st battery +(positive) post..and wire as shown until the negative post is left which will wire to the BLACK wire
RED------+......-...+......-...+......-...+.....- ------BLACK
1 2 3 4
Jun 15, 2009 | Tripp Lite SmartOnline SU1500RTXL2Ua UPS...
Jun 03, 2009 | Tripp Lite Lite SmartOnLine SU2200RTXL2U...
Tripp lite internet office 500
Quit out the screw in the back of the equipment, QUit out the battery power supply under the device.
Greetings
Dec 06, 2007 | Tripp Lite Lite Internet Office 500 UPS...
Tripp Lite Lite SmartOnLine SU2200RTXL2U UPS System Logo
24 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
