Question about Sharp Televison & Video
How to remove the base from a 60inch sharp aquos tv
  • 961 Answers
If you have the model number for the TV, you can more than likley view and/or download the manual for it. This may or may not help you but it's worth a try. If you provide me with the model number,I will see what I can find. http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx This is the link for your tv. Dave
Posted on Feb 07, 2012
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
dsacco86
  • 1077 Answers
SOURCE: I can not remove the stand from my sony aquos tv.
With the 4 long screws removed, it should come out.
Here's where you can download the manual for the LC-46D62U.
http://www.sharpusa.com/files/tel_man_LC46_52D62U.pdf
It has the instructions you need for the stand.
Posted on Jun 02, 2009
  • 441 Answers
SOURCE: I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Posted on Jul 24, 2009
satavlad
  • 405 Answers
SOURCE: Is there a headphone jack on the sharp aquos 46?
There is no headphone jack on this TV
Posted on Dec 05, 2009
How do I remove the back cover of a Sharp AQUOS LC-46D65U LCD TV? I have all the screws out but the section for all the plugins is stopping progress.
If you have removed the base, then remove the speaker compartment which has a lock that holds the plugins part. I repaired a similar tv today at my work shop.
Nov 16, 2016 | Sharp Televison & Video
I lost the 4 short screws for my sharp aquos tv stand model lc 52d62u.i need to know the exact size to replace them.
Google is your friend
This is very late (4 years) but may help someone some day. For my Sharp LC52D64U stand:
Arm to base: 4 - M6 x 35mm
TV to arm: 4 - M5 x 16mm
BTW: base model CDAI-A418WJ36 fits just as well as the original CDAI-A376WJ32 and is usually cheaper on ebay.
http://www.avsforum.com/forum/28-tweaks-do-yourself/1004261-missing-sharp-aquos-screws-help.html
Jun 21, 2016 | Sharp Televison & Video
I have a 60inch sharp aquos tv I was plugging in my hdmi cable to the port on TV and it sparked for some reason and now my tv won't work at all it was fine before that happened
Doesn't sound good. sparks mean high voltage, not good for mainboard electronics. Take it to a Sharp Service facility.
Plugging and unplugging should always be done with everything powered down.
Oct 14, 2015 | Sharp Televison & Video
I need the base table top stand for my Sharp Aquos LC32GP1u TV. I can't find anything under $135! Thats almost half what the TVs worth now
I just got one from a guy named Steve in Santa Barbara. He has at least one more. See eBay by searching for a similar model with a broken screen. FYI, all of the FC-20b... series seem to use the same stand. Good luck
Jan 07, 2012 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
I have a brand new 1day old 60inch sharp aquos led tv since we hooked it up it has had a faint greenish line going vertically right in the middle of the screen. nothing makes it go away. do you know what...
This greenish line is due to physical screen damage. This is not repairable and not your fault.
If you didn't drop this tv, then the TV was damaged in the box.
Return your TV to the store you bought it as soon as possible. The longer you wait, the more chance they'll tell you that you damaged the TV and that they're not responsible for customer's physical damage.
Mar 11, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Brand new 60inch Sharp Aquos. HDTV cable box and HDMI cable attached. Still not as clear as I have seen other tv's. What else can I do?
either change the format on ur cable box to 720p or 1080i....or your hdmi input is broken and you need to use component cable
Oct 10, 2010 | Televison & Video
I cannot remove the base from a Sony KDL-40S2030 tv
did u figure it out? I'm trying to do the same thing.
Thanks Laurie
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Jun 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
532 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
