Question about Refrigerators
LOOSE HANDLE MODEL #795.75289402 KENMORE - Refrigerators
4 Suggested Answers
SOURCE: door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Posted on Feb 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 01, 2011
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
Kenmore microwave model 721 loose door
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
Jan 20, 2014 | Kenmore 62702 Microwave Oven
Kenmore coldspot 106 door handle is loose
Gently slide the handle up until it releases. Then slightly turn the screw underneath it, and slide the handle back on. Do this until it fits properly.
Jul 28, 2013 | Refrigerators
Have a Kenmore model 596.51673100 and the handle is loose how do you tightne it?
see if the plastic part of the handle will snap off, then you can get to the bolts
Oct 28, 2010 | Kenmore 57029 Side by Side Refrigerator
My Kenmore Coldspot side by side door handle is very loose. HOw do I tighten?
Normally on the handle is a cosmetic cover. Use a small flat screwdriver and pry it loose. underneath are the 2 screws you are looking for.
Oct 23, 2009 | Kenmore Refrigerators
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Loose door handle on kenmore refridgerator model#253.5718260
Here is site that has drawings and parts for many fridges.......might get the drawing from here to see what can be done with you handle.
http://www.appliancepartspros.com/partsearch/
Jul 27, 2009 | Kenmore Refrigerators
Door handle is loose
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Electric Range - Door handle
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Jan 03, 2008 | Kenmore 96213 Electric Kitchen Range
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
