Question about Toshiba DVD Recorder AND Series2 TiVo 120GB DVR
Tivo won't eject bad DVD.
My Tivo won't eject an apparently bad DVD. It stays stuck - displaying "Loading". What can I do to get it out?
  • 68 Answers
Unplug power. hold the eject button while plugging in the power cable
Posted on Jan 07, 2009
Coby LCD tv with side loading DVD player, my daughter apparently played with it while I was asleep- I turn it on to watch a dvd now, the dvd is inside (I don't think it's stuck) but won't come out by the...
Mechanical fault. Contact any service technician. The disc loading mechanism should be taken out from the TV for repair.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 26, 2014 | Televison & Video
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
My factory dvd player in my 2003 Mercury Mountaineer has a dvd stuck in it. The dvd will play, but when I hit eject the screen states the loader is blocked. Nothing is jammed or in the loading slot. ...
Unfortunately there isn't an easy fix for an issue like this other than taking it in for service. Some dvd players lock the disc onto a spindle, some use a vacuum type loading system and some use a gear type system for loading and ejecting. Regardless of which type of loading mechanism you have, the only way to fix the problem is to disassemble the dvd player and either fix or replace the bad parts. Sorry to be the bearer of bad news, I wish you the best with it though.
Dec 01, 2010 | Car Audio & Video
Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Jan 02, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
