Question about Coleman CP0302013 20 - Gallon Portable Compressor
Coleman 5Hp Compresser
The compresser will start at low pressuer ands go to peak but it wont restart again at 85psi. all it does is hum
  • jjmerritt Dec 02, 2008
    I have fix the compresser and the problem was the spill valve on the Pressure switch. I have made some modefication and it now works Thanks for you help
    President:
  • Coleman Master
  • 1,388 Answers
All electric compressors share a basic design with ac power pressure switch with unloader and checkvalve between the pump and the tank. When the pressure switch powers off, it unloads the compressor by releasing the air in the discharge hose. You will notice a small tire stem pin and a lever to engage it somewhere on the pressure switch. If the compressor stops before reaching set cutoff point, the air pressure remains in the discharge hose not allowing the motor to start, thus the hum you hear. Solution is to check for the proper function of pressure switch /unloader, tank check valve (if check valve leaks air back to compressor it will load motor causing hum) and extra measure check capacitor for at least 90% of rated valve. Finally, do not run this compressor with an extension cord, use more hose instead. enjoy
Posted on Nov 29, 2008
  • brian
    brian Nov 04, 2013
    what do you do to unload the motor so it will start again and were to I get a new pressure switch?
Air compressor wont produce more than 60psi
clean the one way cheak valve on the head of the air compresser motor whier the big line comes out and goes to the tank.
Sep 09, 2012 | Coleman Powermate 27 Gallon Air Compressor
Model hl410100 the compresser works well until the pressure reaches about 75lb then the motor stops but keeps trying to turn as soon as you bleed off some air the motor starts again until it hits 75lb.It...
might be a bad check valve and do nut use an extension cord ever on a air compressor it will over time damage the motor plug it in directly and use longer hose
Jul 06, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My Bostitich air compresser wont start to refill
I would suspect that your pressure switch is defective and should be replaced
Dec 04, 2009 | Air Tools & Compressors
I ran my up-right 5hp compresser out of oil. will
YA YOU CAN DO YOU HAVE A OIL LEAK LD CK THAT IF YOU NEED PATR NUMBERS SEND ME THE MODEL NUBERS AND ILL GETEM FOR YOU AND TELL WERE TO GETEM
Oct 22, 2009 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
2003 ford explorer ac compresser wont come on
possibly low on freon thers a switch that will not let it engage if pressure is to low!!! hope this helps you!!!also check for 12v at compressor!!good luck!!!
Jun 22, 2009 | 2000 Ford Mustang
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Coleman CP0302013 20 - Gallon Portable Compressor Logo
491 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
