Question about Intermec CK30C (CK30CA1331002804) Portable Terminal
Keyboard anytime i press any letter on the keyboard the letter together with alpha appears on the screen. this only happens when you are in TE200 mode.
  • jmohammed87 Oct 22, 2008
    alpha appears on the screen. this only happens when you are in TE2000
    mode.
  • 61 Answers
Try restoring the device to factory defaults. You will have to reinput settings, but it should fix the problem.
Posted on Apr 05, 2009
I can not get a letter to appear on my keyboard
I understand that a letter is not displayed on a screen while you press the key. Since this difficulty is happening for a single letter, I think the issue might be hardware related. To confirm that it is a hardware issue, you can try an external keyboard.
If the letter is not displayed even while using the external keyboard, you might need to reinstall the keyboard driver or restore the system or reinstall the operating system.
May 23, 2013 | Dell Computers & Internet
On a TI-84 plus calculator how to I put letters such as x, b, e etc. into an equation.
To type a letter of the alphabet, use the ALPHA keyboard. Press the ALPHA key followed by the letter you want.
Nov 27, 2012 | Texas Instruments TI-84 Plus Silver...
I would like to add hold number
In order to store a number in your calculator, press "STO->" and enter a letter by pressing ALPHA and then whatever key has the letter you want on it. For example, pressing STO->, then ALPHA and then the MATH button will store whatever your previous answer was in the letter A. Then, anytime you enter the letter A into a calculation, your calculator will use the value you stored in the calculation.
Jan 11, 2011 | Texas Instruments TI-83 Plus Calculator
How do i enter linear equations on my casio fx-115es? 3p+6=10+2p
You can enter equations of any type. Read the rest of the post. Keep in mind that if you are using the Solve( function X must be the unknown. If you are using the Table computational mode, X is the independent variable and Y the dependent one.
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 you proceed as follows.
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you enter the equation you are dealing with, and before pressing anything else, press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter. Once all non-X variables (if any) are given values, the calculator will return with the solution. You will see on the screen L-R= (should be zero if you are lucky).
Nov 11, 2010 | Casio FX-115ES Scientific Calculator
How do I use the calculator to get x and y in variables?
Sep 07, 2010 | Casio fx-300ES Calculator
How to use the calculator to solve simple equations?
Sep 05, 2010 | Casio FX-115ES Scientific Calculator
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for...
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Jan 19, 2010 | Dell Latitude D610 Notebook
Unable to use the integration function
First you have to computational mode to [MODE][1:Comp]. Then press [SHIFT][MODE][1:MthIO].
Press the Integral, a template with the distinctive Integral (Snake) sign appears, with two small rectangles for the limits, a larger rectangle for the function, and dx.
The cursor will be blinking in the large level-line rectangle. Enter your function using the [ALPHA] [Letter] combinations to enter X,Y,A,B,C,or D, then use the Down Arrow to enter the lower limit, then the Up Arrow for the upper limits.
After you finish press the [=] to get the numerical result.
You cannot obtain primitives, just numerical values.
Mar 30, 2009 | Casio FX-115ES Scientific Calculator
KEYBOARD PROBLEM
My Blackberry 8310 curve key board is not working properly. When I press 5 nothing happens on the screen, when i press 4,7,and some of the letters dont work at all till i move them arround .
Jun 26, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have just bought my son a laptop,i cant get connected to my live box it says the wireless is on but the light is not on also on the keyboard i have to hold the fn button down to use the letters m j k l u...
Have a look at the F keys at the top of the keypad. The fn key is a toggle key. It changes the mode to something and then back again when you press it. There will be an F key with a picture of a keyboard on it (probably) (Dont press the one with the the picture of a computer on or your screen will go off)
Press fn and the keyboard Fkey together to toggle back to alpha keyboard rather than numeric.
Mar 25, 2008 | Computers & Internet
Intermec CK30C (CK30CA1331002804) Portable Terminal Logo
85 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
