Question about Watches
The crown won't screw down on my watch - Watches
  • 65 Answers
SOURCE: Cant screw in screw-in crown
It's possible you may have stripped the thread or cross-threadded it. If you have a magnifier check the condition of the thread on bothe the inside of the crown and outside of the pendant.
Posted on Aug 23, 2009
  • 55 Answers
SOURCE: crown will not screw down
The model 3001 does not have a screw down crown, but is just as water resistant as a screw down style
Posted on Dec 26, 2009
  • 2501 Answers
SOURCE: I need spare part for my k3 submarine watch: I
Assuming that these parts are unique to your make of watch, then according to their web site there are no distributors in Austrailia.
If you go to their web site (www.vostok-europe.com/), you will see a map of the world and the countries that have distributors are shown in red.
Your nearest distributor is in Indonisia but you could just a easily order one from an English speaking country (to increase the chances of getting what you want!)
Posted on Feb 02, 2010
Testimonial: "Thanks for confirming what I knew already."
gemineye61
  • 831 Answers
SOURCE: can I swim laps w/ my ebel 30 meter watch? The
Thank you for contacting FixYa.
Water Resistant is a common mark stamped on the back of wrist watches to indicate how well a watch is sealed against ingress of water. It is usually accompanied by an indication of the static test pressure that a sample of newly manufactured watches was exposed to in a leakage test. The test pressure can be indicated either directly in bars, or (more commonly) as an equivalent water depth in meters (in the United States sometimes also in feet).
An indication of the test pressure in terms of water depth does not mean a water resistant watch was designed for repeated long term use in such water depths. For example, a water resistant watch marked at 30 meters depth cannot be expected to withstand activity for longer time periods in a swimming pool, let alone continue to function at 30 meters under water. This is because the test is conducted only once using static pressure on some of the newly manufactured watches. The test for qualifying a diving watch for repeated usage in a given depth includes safety margins to take factors in account like aging of the seals, rapidly changing water pressure and temperature, as well as dynamic mechanical stresses encountered by a watch. Also every diving watch has to be fully tested for water resistance.
Hope this helps.
Jewel
Posted on Sep 02, 2010
SOURCE: hello, my new Tagheuer aquaracer calibre 5 500m
I have the same problem with mine....They have some kind of manufacturer malfunction , tag will not admit. My is in the shop for the 3rd time ...at this point they should replace my watch...this one is a lemon.
Posted on Mar 25, 2011
Cannot set time for time for tag heure CL111a
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch. Nice watch, Michael
Nov 05, 2011 | Watches
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
Cant set wrist watch
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
I cannot pull out the time setting screw on the rhs of a ladies wn311 Tah Heuer.
The time setting screw is more accurately called the crown which is, in your case, a 'screw down crown'. This is done for water resistance. You must first unscrew the crown before you can pull it out. When you are finished setting the watch you must screw it back in. It may require that you press in on the crown and turn it at the same time to get the threads to catch. No need to overtighten it.
Oct 30, 2010 | Tag Heuer 2000 Classic WK1311 wristwatch
How do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Jun 26, 2010 | Invicta Subaqua Noma Iii S
Im trying to adjust the time because it stopped when i took it off for a day. Im not sure how i can change it because the adjusting knob is not popping out.
mcdevito75 here, Tissot a very, very great name and watch, a you know most stems pull out to set the time, some watches have a screw down crown this adds to it"s waterproofing as there is a gasket under the crown. Maybe your Tissot has this screw down crown, simply un screw the crown then gently pull up on the crown to set the time. If this fails, see any Jewler for help, doN't mess with the watch to much a syou or anyone could wreck it, and Tissot is very expensive.
Jun 24, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Screw down crown wont lock
There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
Rate me, plz.
Jan 06, 2010 | Watches
Crown will not screw down
Dec 16, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
Screw down crown wont screw down
Either the crown or the case tube threads are stripped. Which ever part is stripped needs to be replaced. Keep in mind that both could be the problem. Be sure you don't get your watch wet until this is fixed. Your watch is NOT sealed for water resistance if the crown does not screw down.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Tag Heuer WAH1112.BT0714 Formula 1 watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
