Question about Honeywell Heating & Cooling
Honeywell RTH2310 Light always lit, Temp stuck at 85, constantly cools
Replaced batteries, now temp display stuck at 85 and won't adjust up or down. Constantly cooling. Never cycles.
  • 6 Answers
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Posted on Jun 25, 2009
heatman101
  • 43501 Answers
SOURCE: Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 12, 2009
heatman101
  • 43501 Answers
SOURCE: Honeywell CT500 Electronic Thermostat showing
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Posted on Aug 13, 2010
  • 224 Answers
SOURCE: I purchased a Honeywell RTH2310
I am only guessing here but I believe that the thermostat may need to be gone over as far as the wiring from the thermostat to your heater. A thermostat is basically a switch that operates by way of a thermometer. On the wiring it has red and white wires these control the heat section of your furnace/ heater. They also go down the wall to the heater where it should have terminals to a transformer to convert control voltage to 24 volts, red takes 24 volts to the thermostat and white returns back down to a 24 volt relay to turn on the heater. if at any point the red and whit touch any where the thermostat does nothing at all. That means there may be a short some where in the red and white wires. To check this use a volt ohm meter, disconnect the red and white wire from the thermostat and test with one lead on each wire, a dead short reads 0. There may be slight readings thru the relay, so to check only the wires power down the heater disconnect the red and white wires at the heater and again read only the red and white wires with out being attached to anything it should read open. If not replace thermostat wiring. Inspect the wires for cuts where they come thru the wall and go thru the furnace. Most common places where the wire gets cut or pinched is where it is feeding thru the heater case.If all rings out fine it could be a faulty thermostat. This is a lot of instruction but you are looking for a short and this is the easiest way to go about it.
Posted on Dec 22, 2010
  • 81 Answers
SOURCE: I have a Goodman central
I checked the model #'s and they should interchange just fine. Double check your wiring. On the thermostat Red to Rc (which should also be jumped to Rh), White to W, Green to G, and Yellow to Y. Move T-stat controls from current position to oposite end and back to what you want to run ie. A/C if thats what you want. Move fan control to on and back to auto. (I find this eliminates some close but not quite right settings). This should work. If not look in furnace to verify how it is wired. Any colors that do not match the above will be your corrective action to do at the thermostat. if necessary change t-stat wires at t-stat to match what is in the furnace.
Posted on Feb 14, 2011
My Honeywell goes to 85 degress when I am trying to lower to 78. Tried hitting run then set temp them hold. Still jumps back to 85 or more. Changed batteries..no help
Run means you are running the program. Hold means you want to hold the set temp and not run the program. Change the temp, press hold. Hold should be displayed on the screen when not running the program.
Jul 22, 2017 | Honeywell Heating & Cooling
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
I have a 1999 Alero 3.4 V6 the cooling fans won't run. I checked the fans they both work if I unplug the harness for the temp sensor,the relays and fuses are fine,I replaced the coolant temp sensor and...
CHECK MODE RELAY IF BOTH RELAYS GOOD YOU CAN CHECK RELAY BY REMOVING IT FROM FUSE BOX HOOK RELAY TERMINAL 85 TO BATTERY POSITIVE AND GROUND TERMINAL 86 IF CLICKS RELAY GOOD. IF RELAY GETTING POWER GOOD AND THE 30 AMP COOLING FAN FUSE OKAY.EITHER THERE IS A SHORT IN COOLING FAN WIRING OR THE PCM HAS FAILED.THE PCM HAS LOST OR COMMAND RUN CIRCUIT IN PCM SHORTED OUT DUE TO PCM FAILURE.LET DEALERSHIP OR GARAGE USE DIAGNOSTIC EQUIPMENT TO ACTIVATE THE PCM SEE IF IT HAS FAILED.DONT SPEND MONEY ON NEW PCM COULD BE SHORT IN THE WIRING CIRCUIT
Sep 06, 2011 | 1999 Oldsmobile Alero
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
32 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
