the part that causing the mulching is a plug that fills the discharge chute and redirects the clippings back to be recut.
they are available from a mower shop as a spare part
might even be available for your mower on e- bay
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
