Question about John Deere Garden
John deere e35 edger operator manual - John Deere Garden
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: john deere edger E35 kawaski motor fa130d spark is
Hi alger...
To disassemble your carburetor is easy,
Before you dissemble the carburetor make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor, so that you will know which way it goes back together when you reassemble it.
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
NOTE...
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Your carburetor should be working properly to run now as long as you do not have other problems in the fuel system or electrical problems.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 22, 2011
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
If brakes are not locked together on steep ground the John Deere tractor will kick out of 4wheel drive and run away.
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/...A9/Output/OMM139226_A95.html
Slow down before you make a sharp turn or operate on a slope. ... Before starting engine to drive tractor, adjust operator seat to desirable position. ..... If lock does notdisengage, depress one turn brake pedal, and then the other. ... The 2-wheel drive (2WD) / 4-wheel drive lever (A) enables the tractor to be operated in two or ...
A Guide To Safe Farm Tractor Operation - National Ag ...
Nov 23, 2015 | John Deere Garden
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
Where do u place the attachment lift lever on a john deere L130 r where can i find a diahgram for it
manuals.deere.com/cceomview/OMGX21647.../OMGX21647_K35.html
Picture Note: Console on Models L120 and L130. A - Throttle ... Put attachment lift lever (A) into the slot adjacent to desired cutting height. · Slide the height ..
Aug 18, 2015 | John Deere Garden
No operators manual
I doubt your going to find a free manual for anythng John Deere makes let alone an older tractor. However..... You can get an operator's manual direct from JOHN DEERE by calling 1-800-522-7448 with credit card in hand.
A bit about the tractor itself. Note the links On the linked page below:
http://www.tractordata.com/farm-tractors/001/8/0/1801-john-deere-1640.html
Again.. even with a source as good as that webpage you do not see an Operator's or an Owner's manual link.
IF your doing a course at a local college, try the college bookstore first. The manual will be much cheaper than buying it from John Deere.
Thanks for using FixYa,
Kelly
Apr 21, 2010 | John Deere Tractor 1020, 1520, 1530,...
Garden Logo
936 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
