SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
11321 11444 32124
.............14343 14422 21422 22112
.............22431 22443 23143 23212.
Just try with these codes with your remote control which you owns now, and find whether it works or not. If not, buy the remote mentioned above.
If you know the brand of your equipment, look at the code list at the
back of this booklet, and find the first 5-digit code for your equipment.
1 Press and hold s and y at the same time until the green LED lights
up. (Release the keys, the green LED should stay on)
2 Enter the 5-digit code using the numbers that correspond to the
function keys
The green LED blinks twice.
That's it! Now, press a few keys on the remote to check that the
equipment responds correctly. If it doesn't, try again using the next code
in the list. In the rare instance that none of the codes work, follow the
instructions in the next section.
Tip: Make a note of the code inside the battery case, and in the back of
this booklet in case you ever need to setup again.
You will get its catelogue along with its pack to refer more. OK.
